JONES Posted June 23, 2008 Report Share Posted June 23, 2008 i was just on the cascade inn. website and they have a aluminum bracket that replaces the stock cage for better air flow. They say its for larger cc engines. it only cost 10 bucks so i dont know but it looks like it would make a difference. so if u or anyone has used it let me know thanks Quote Link to comment Share on other sites More sharing options...
wesw Posted June 23, 2008 Report Share Posted June 23, 2008 i would suggest getting them really opens up the reed cage. good product. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 23, 2008 Report Share Posted June 23, 2008 Yea for ten bucks you cant go wrong. When you really need to have them is when you have a boss or any other intake that has a big square opeaing in the back. Helps match things up. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted June 23, 2008 Report Share Posted June 23, 2008 i was just on the cascade inn. website and they have a aluminum bracket that replaces the stock cage for better air flow. They say its for larger cc engines. it only cost 10 bucks so i dont know but it looks like it would make a difference. so if u or anyone has used it let me know thanks Do you have a large cc engine? Whats done to your engine? What pipes? Quote Link to comment Share on other sites More sharing options...
tiffnaub Posted June 23, 2008 Report Share Posted June 23, 2008 I have a 421 cub 4mil and i think they work fine Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 23, 2008 Report Share Posted June 23, 2008 I'd only run them to match up the intakes.. if you have the round style opening on your intakes... I'd stay with the stock stuffers.. JMO Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted June 23, 2008 Report Share Posted June 23, 2008 I'd only run them to match up the intakes.. if you have the round style opening on your intakes... I'd stay with the stock stuffers.. JMO Same here. Thing is they will increase top end flow, but will decrease low end velocity. Typically the vf3 is more of a large flow reed cage and should usually be used where the capacity of the stock cage is surpassed or on a drag motor. For low or mid increases in power the stock cage with a good set of reeds will do a better job in the lower part of the power band. Quote Link to comment Share on other sites More sharing options...
XxMeltIcexX Posted June 23, 2008 Report Share Posted June 23, 2008 I run them in my trinity intakes, only reason they should be used is if the intake is a square bore. Only makes sense on a large motor or small motor, its like port matching your cases to your cylinders. Quote Link to comment Share on other sites More sharing options...
