gmctruck1976 Posted June 21, 2008 Report Share Posted June 21, 2008 Well guys wanted to see if you all would mind me doing a video of my rebuild. Im doing a 4 mill from seals on up build. I would like to make one as informative as possable for free. Its a pain in the but looking up info here and there. Im planning on putting a lot of detail most over look when doing a video. I know it will not be up to others standards for exstreme output. But ill try to to go in to as good of detail as possable and cut it into different parts of the build Its just a thought. Ill be doing this this winter and got nothing esle planed. heres a list of what ill be doing o Tear down every thing but rolling chassie o Cleaning frame and painting o Install nerf bars o New tires and rims o Front shocks o complete engine break down o replacing all seals o replacing stock crank with 4 mill o checking gears o replacing water impeller o replacing pistons o changing heads from stock to a cool head with domes o replacing clutches o complete reassembe and doing torq o checking clearences o leakdown test o compression test o installing ajustable timing plate o removing tors system for trinity 2 into one carb set up o reinstall of motoer and new plastic o new pipes o fluids o break in Seems like a long video hopefully i can do some movie magic with it to make it useable well what are your thoughts guys. Im no master mechanic, but what im doing isnt rocket science. That parts for the porting guy. Hopefully Ill figure this one out some day to and send a video on that one too.I have got nothing but time to learn to do that and that is comming along well. I may stick porting in this as well but it will be for a woods port only, but once i get the timing area completly figured out. and how to use this software ill stick that along with it Well guess thats enough for one post Hope to meat some of you on the trails keep the Banshee alive Quote Link to comment Share on other sites More sharing options...
brugal Posted June 22, 2008 Report Share Posted June 22, 2008 Im pretty sure Nitrotate is already doing one. Quote Link to comment Share on other sites More sharing options...
