LIM_Whiteboy4life Posted June 21, 2008 Report Share Posted June 21, 2008 I think one of my bores are ovaled and im getting very early signs of piston slap. How do i know? well Im getting a tick until it warms up and the whole metal expans theroy cures it but how long can that last? lol. If anyone else has had piston slap before tell about what you heard, how it ran, ect.... might help. :beer: Quote Link to comment Share on other sites More sharing options...
deckheight Posted June 21, 2008 Report Share Posted June 21, 2008 No accurate way to do it other than disassembly and inspection with mics and bore gauges that I know of. Sorry Quote Link to comment Share on other sites More sharing options...
2bzy2p Posted June 22, 2008 Report Share Posted June 22, 2008 imo the signs you speak of you do have piston slap,best way is to take the top end off as mentioned. Quote Link to comment Share on other sites More sharing options...
b00sted Posted June 22, 2008 Report Share Posted June 22, 2008 I think one of my bores are ovaled and im getting very early signs of piston slap. How do i know? well Im getting a tick until it warms up and the whole metal expans theroy cures it but how long can that last? lol. If anyone else has had piston slap before tell about what you heard, how it ran, ect.... might help. :beer: Most LS1 camaros/vettes/firebirds come from the factory with piston slap...And they'll go for 150k miles without any issues. My firebird sounds horrible until it gets warmed up(and then it mostly goes away). The car still makes all the power it did from the factory(13.0 with just a catback.stock auto trans/ 97k miles). Just warm the motor up well before you go beat on it and it shouldn't be an issue for quite a while. I don't think you'll have any performance loss until the piston/wall tolerances open up too much and you start to lose compression. Quote Link to comment Share on other sites More sharing options...
fast500#12 Posted June 22, 2008 Report Share Posted June 22, 2008 if you have the engine under heavy load ( climing a hill with good traction) and pin it. if you have piston slap you will for sure hear it then. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 22, 2008 Report Share Posted June 22, 2008 Piston Slap in a 2 stoke is a good way to get a broken skirt. I bet your firebird doesnt turn 10,000 RPM. This is why you should check the compression a couple times a year. Write it down in a book some where. That way you have all your compression readings starting from when it was a new top end. You can compair your current readings and tell when it is time for a new top end. josh Quote Link to comment Share on other sites More sharing options...
b00sted Posted June 22, 2008 Report Share Posted June 22, 2008 Piston Slap in a 2 stoke is a good way to get a broken skirt. I bet your firebird doesnt turn 10,000 RPM. This is why you should check the compression a couple times a year. Write it down in a book some where. That way you have all your compression readings starting from when it was a new top end. You can compair your current readings and tell when it is time for a new top end. josh Nope, 6500. But if the motor warms up and the piston slap goes away, it shouldn't cause any problems. If you beat on it while it's still cold, then sure. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 23, 2008 Report Share Posted June 23, 2008 If your experiancing piston slap with the motor warmed up to opperating temperature that is when you will start getting in trouble. Quote Link to comment Share on other sites More sharing options...
kawiking Posted June 23, 2008 Report Share Posted June 23, 2008 my motor blew acouple of months ago ..piston skirt snapped off... started it in feb (cold) i could hear a tick noise when it was cold, reved it to see where it was coming from... then i heard it go !!! piston flying out the pipes, it was to late.. id take it apart and mic it !! Quote Link to comment Share on other sites More sharing options...
