i want to learn so bad
mtg
can anybody give me some tips on how to wheelie a shee. i want to learn so bad.
Keep your weight back and after you've got the front end up keep it balanced. Make sure you keep your foot on the rear brake and if it goes too far back you can tap the brake to bring it back down. Then practice and you'll get better and better at it.
When I first learned on a dirtbike I would just gun it in first gear and bring the front up. Then I'd bring it higher and ride it out longer until I reached the balancing point. Then I started doing the same in 2nd gear. And then someone suggested I start shifting gears once I get it balancing in 2nd...And I've been doing badass wheelies ever since. I was on a 4 stroke though, so it had great torque off a low rpm, and good engine braking...Keep your foot over the rear brake because if you go too far backwards that'll be the only thing to help you on a 2-stroke.
And out of the 100's of wheelies I've done, I've crashed twice. Both times sucked. First time taught me not to start the wheelie in 1st and shift to 2nd, because for somereason 2nd hit too hard and the bike would go over backwards quick. The second time taught me to not try doing wheelies with a cold motor...Because it sputtered, I gave it more gas to keep it going, and then the power came back and I went off the back again. I skinned my knees and forearms decently...And my first reaction was to jump up and push the bike home...And I felt great until I got in my house, and then I felt like crying because it burned so bad.
Edited by b00sted
can someone tell me how to hit 100 foot gaps while your at?
You gotta keep it pinned in sixth! :biggrin: lol
Your right, riding wheelies are much easier for me on my 700 than on the Shee. The Shee is so high strung it's difficult to keep the front end from rocketing up too far everytime I give it a little gas to help balance it out.
