The Faster Cracker Posted June 20, 2008 Report Share Posted June 20, 2008 ok so i went to adjsut my chain yesterday and noticed that i had some slack in the front sprocket. it moves sided to side as in to and from the case not front to rear of quad. about a 1/4inch. thats not normal right? what do yall think it could be? Quote Link to comment Share on other sites More sharing options...
P-man Posted June 20, 2008 Report Share Posted June 20, 2008 is the nut tight? Quote Link to comment Share on other sites More sharing options...
The Faster Cracker Posted June 21, 2008 Author Report Share Posted June 21, 2008 nut is tight and so is the retaining washer. the spacer is in there as well Quote Link to comment Share on other sites More sharing options...
brugal Posted June 21, 2008 Report Share Posted June 21, 2008 A little play is normal.Nothing to worry about. Quote Link to comment Share on other sites More sharing options...
The Faster Cracker Posted June 21, 2008 Author Report Share Posted June 21, 2008 cool thanx man Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted June 21, 2008 Report Share Posted June 21, 2008 (edited) no thats not normal, how is it supposed to stay true to the back sprocket if its moving in and outh ont he shaft? the only thing i could think u did wrong was maybe you didnt seat the lockwasher behind the nut on the grooves right? with the sprocket on, theres barley enough meat sticking out left on the grooves of the shaft to hold that lockwasher in place without its falling down and off the grooves if you know what i mean, it could have fell off the grooves while you were tightening the nut, and the nut is only tightened down against the lockwasher which is torqued down against the end of the splines and not against the sprocket like it should be, i hope that made sense or maybe it was like my friends was the other week, he took his chain off to change the swingarm, i grabbed his front sprocket out of total randomness and it had a shitload of play in and out like yours, he thought the nut was tight cause he couldnt spin it, but it was just tight enough to keep the lockwasheer on the grooves then bent around the nut , it had in and out play but just barley tight enough to keep the sprocket from falling off the splines Edited June 21, 2008 by Michael Jackson Quote Link to comment Share on other sites More sharing options...
