05.Banshee.SE Posted June 19, 2008 Report Share Posted June 19, 2008 Here's some mods I want to do soon: 1. K&N - What would you reccommend for an '05 stock 'Shee? 2. T5s vs. T6s? 3. Boost bottle? (I've heard both sides: do it, it's cheap enough...and don't waste your money.) I would also like to do V-Force 3 Reeds (whole assembly, not just replacement reeds.) ------ After that....what order should I do them in? I'd like to hold off on exhaust, and do intake first because of the price. What other simple [bolt on type] things am I missing? (I want to wait for porting, etc. a few months) Bike will be for dirt road/sand/sand dune/street use. Will NOT see water. Quote Link to comment Share on other sites More sharing options...
okbeast Posted June 19, 2008 Report Share Posted June 19, 2008 Seeing no water I'd go for k&n pods. T-5's if you want porting down the road (or more top-end pull) Adjustable timing plate No boost bottle Coolhead or milled head. Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted June 19, 2008 Author Report Share Posted June 19, 2008 Will removing the pressurized stock airbox cause me to lose some low end drivability? I'm going to port eventually...I'm just trying to stay out of motor work for now, since the bike is so new. I'm going to find a local shop that has a good reputation to do it, but I'm still kinda nervous about it. I'll nix the boost bottle, and look into the adj. timing plate. Will the cool/milled head change my required octane fuel? Quote Link to comment Share on other sites More sharing options...
okbeast Posted June 19, 2008 Report Share Posted June 19, 2008 Pods wont affect low-end, never heard of that affecting it. If you keep your compression around 150 you can run pump gas. Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted June 19, 2008 Author Report Share Posted June 19, 2008 I'll look into all that stuff. Thanks a lot man. Quote Link to comment Share on other sites More sharing options...
okbeast Posted June 19, 2008 Report Share Posted June 19, 2008 Anytime, if you have questions on any of that the search should have quite a bit of info, just do a little diggin. Quote Link to comment Share on other sites More sharing options...
jamebo Posted June 19, 2008 Report Share Posted June 19, 2008 I recommend a Nosshead. They work great, use the existing studs, and install pretty quickly. You should be fine with the 21cc domes to run premium unleaded. You'll notice a difference in power right away. Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted June 19, 2008 Author Report Share Posted June 19, 2008 Just ordered: TORS Removal Kit. K&N Pods w/ Outerwears. :biggrin: Upcoming: Reeds and Reed Cage (V-Force 3) [should I get a spacer also?] Pipes (Toomey T5s) Quote Link to comment Share on other sites More sharing options...
Hilarious Posted June 19, 2008 Report Share Posted June 19, 2008 Just ordered:TORS Removal Kit. K&N Pods w/ Outerwears. :biggrin: Upcoming: Reeds and Reed Cage (V-Force 3) [should I get a spacer also?] Pipes (Toomey T5s) no you dont need reed spacers. i'd suggest getting the timing plate and cool head before throwing down on the vforces. 21cc domes and advance the plate to +4. Quote Link to comment Share on other sites More sharing options...
okbeast Posted June 19, 2008 Report Share Posted June 19, 2008 no you dont need reed spacers.i'd suggest getting the timing plate and cool head before throwing down on the vforces. 21cc domes and advance the plate to +4. agreed Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 19, 2008 Report Share Posted June 19, 2008 agreed Yep. Reeds dont actually increase power much. They do make it more responsive though. Quote Link to comment Share on other sites More sharing options...
magz Posted June 19, 2008 Report Share Posted June 19, 2008 Yep. Reeds dont actually increase power much. They do make it more responsive though. you should have baught larger jets since your getting pods. my set up pods, adjustible timing plate, v-force 3, t-6's, running stock pilot(25) and 320 mains, bike runs good at all levels of throttle Quote Link to comment Share on other sites More sharing options...
sinisterboo Posted June 19, 2008 Report Share Posted June 19, 2008 I can vouch for Magz bike running good..... LOL Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted June 20, 2008 Author Report Share Posted June 20, 2008 I'm not expecting the pods and TORS kit until next week sometime. I'll order the jets here soon (today/tomorrow), have everything next week and install it all. Quote Link to comment Share on other sites More sharing options...
sredish Posted June 20, 2008 Report Share Posted June 20, 2008 forget the boost bottle. forget the intake and reeds until you get some pipes. i'd get pipes first and foremost... best bang for the buck by far and the reeds aren't going to do squat with the stock exhaust. If you want cheap filters, go to Rocky Mountain and order the cheap K&N pods for like $40 a pop and clamp them on. i would say you should do this, in this order: pipes noss head (smaller cc domes) intake reeds timing plate (can add at anytime really) you'd be a lot happier Quote Link to comment Share on other sites More sharing options...
