PhantomMs1 Posted June 17, 2008 Report Share Posted June 17, 2008 Maybe I am just blind or not good at finding parts, but where can I find a new Steering Stem Bearing? Any Idea of how much they are? thanks! Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted June 17, 2008 Report Share Posted June 17, 2008 I got one you can have if you send me the yamaha tool that gets em out the frame...lol There a bitch to get out cause there is a opposite socket locking it in and the only way i can get it out is with a hammer and a screw driver. I'm sure you already know that since your needing a bearing. Make sure the steering stem collar is still on the bottom they fall out sometimes and if it's not there the stem moves up and down. They run 7 bucks from yamaha Quote Link to comment Share on other sites More sharing options...
PhantomMs1 Posted June 17, 2008 Author Report Share Posted June 17, 2008 yeah unfortunitly i do know about it..........bad thing is I learned about it after I had it powdercoated! so i have to probably get a punch tool to get it out huh? so is that the only way to get it directly from yamaha? maybe a frame up restoration wasnt such a good idea (sigh)...... Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted June 17, 2008 Report Share Posted June 17, 2008 No it's not a big deal, your better off like i said getting a hammer and a screw driver and just slowly working that lock nut out then remove the bearing and just order one from your local yamaha dealer probably cost you 15-20 for the bearing and another 8-10 for that lock nut. I know it's just a steering stem bearing but i always replace em' if i have any doubt. Especially if it has powdercoat all on it...lol Quote Link to comment Share on other sites More sharing options...
PhantomMs1 Posted June 17, 2008 Author Report Share Posted June 17, 2008 yeah, thanks kaos! I will try that tonight. I wish the rebuild would just be done I do not want to put it back together I just want to ride it........oh well it will be worth it when its done thats what I got to keep telling myself anywyas Quote Link to comment Share on other sites More sharing options...
ahcgt Posted June 17, 2008 Report Share Posted June 17, 2008 yeah unfortunitly i do know about it..........bad thing is I learned about it after I had it powdercoated! so i have to probably get a punch tool to get it out huh? so is that the only way to get it directly from yamaha? maybe a frame up restoration wasnt such a good idea (sigh)...... Either bikebandit.com or rivamotorsports.com will have what your looking for. I tend to go with bikebandit.com because shipping is usually much quicker. They have a pretty good oem parts finder that gives a picture and name of everything you should be looking for. Hope this helps. Quote Link to comment Share on other sites More sharing options...
PhantomMs1 Posted June 17, 2008 Author Report Share Posted June 17, 2008 Either bikebandit.com or rivamotorsports.com will have what your looking for. I tend to go with bikebandit.com because shipping is usually much quicker. They have a pretty good oem parts finder that gives a picture and name of everything you should be looking for. Hope this helps. I tried rockymountain but they did not have them, will have to check out those other sites! thanks! Quote Link to comment Share on other sites More sharing options...
ahcgt Posted June 17, 2008 Report Share Posted June 17, 2008 I tried rockymountain but they did not have them, will have to check out those other sites! thanks! Either of those sites should have about every bolt/nut/bearing/gasket. I'm doing a frame up restore too and just got a complete bolt kit from alloyboltz.com. Pretty good stuff. Check that out too. Quote Link to comment Share on other sites More sharing options...
okbeast Posted June 17, 2008 Report Share Posted June 17, 2008 To get that reverse nut out find a bolt to fit it then use a pipe wrench. That's what I did. Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted June 17, 2008 Report Share Posted June 17, 2008 To get that reverse nut out find a bolt to fit it then use a pipe wrench. That's what I did. That's also a good idea, just put two nuts on the bolt and bind the bottom nut to the top and start unscrewing. Quote Link to comment Share on other sites More sharing options...
PhantomMs1 Posted June 17, 2008 Author Report Share Posted June 17, 2008 very good idea, but that is a pretty hefty bolt. Know what size it is by chance? Quote Link to comment Share on other sites More sharing options...
Hilarious Posted June 17, 2008 Report Share Posted June 17, 2008 30 or 32mm not really sure. i took a trailer hitch ball and tightened the nut on the bottom of it and used that to screw mine out. :smile: Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted June 17, 2008 Report Share Posted June 17, 2008 I used a bolt and welded the nut to it. The head of the bolt measures: 1 1/8" Also I bought an "All Balls" kit off of ebay. It came with both seals also. Ryan Quote Link to comment Share on other sites More sharing options...
NitroTate Posted June 17, 2008 Report Share Posted June 17, 2008 Hey guys another option is available at Home Depot and also at Harbor Frieght. They make this special socket set for plumbing and there is one in there that almost fits, it's a little loose and sloppy but it worked for me and they are really cheap. I bought mine for about $15. at home Depot but then found them at Harbor frieght for like $10. Quote Link to comment Share on other sites More sharing options...
PhantomMs1 Posted June 17, 2008 Author Report Share Posted June 17, 2008 would they have that at lowes do you think? I might have to stop off and buy that for this weekend. Quote Link to comment Share on other sites More sharing options...
