help with flywheel puller won't thread
decon
Just a dumb question but you are turning it left right? The flywheel is left hand threads. First try cleaning the threads and see if you can get it to start but if the threads are stripped out either a 3 jaw puller or take the standard puller center it up on the flywheel and weld it this will ruin you puller and flywheel but it will get it off at a last resort...
yes i know its reverse threaded. i will try to clean the threads on the flywheel, i know the flywheel puller is good because it threads to my extra flywheel. but if worse comes to worst, where do i get the jaw puller from.
