Beatty89 Posted June 14, 2008 Report Share Posted June 14, 2008 Hi, I recently put a rod through my case so the banshee is in rebuild stage..Its ported and i ruined one of the cylinder jugs..Do i need to get the jug ported or will it be fine with one side ported and other side not..Ive called a couple macanics and some say it needs to be and others say the other piston will pick up the slack for the un ported side..Moneys tight and i really want to get it running..thanks Josh Quote Link to comment Share on other sites More sharing options...
Frogger Posted June 14, 2008 Report Share Posted June 14, 2008 They need to be the same. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 14, 2008 Report Share Posted June 14, 2008 whoever told you it would be ok needs to be shot. i wouldnt trust that person anymore.. they need to be the same. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted June 14, 2008 Report Share Posted June 14, 2008 whoever told you it would be ok needs to be shot. i wouldnt trust that person anymore.. they need to be the same. Agreed, don't ever call them again. Once again, the sig is great Loco! Quote Link to comment Share on other sites More sharing options...
Dinner Posted June 14, 2008 Report Share Posted June 14, 2008 As everyone else has said, you will have to get both cylinders ported. That would be like trying to run a drag ported cylinder with someone's dune ported cylinder...just ain't gonna work :yelrotflmao: Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted June 14, 2008 Report Share Posted June 14, 2008 Welcome to the HQ :thumbsup: As said above, both cylinders need to be the same. The reason this is so crucial is stress on the crankshaft and harmonics/vibration, if one side is applying more force than the other your chances of slipping your crank out of phaze is worse. Not to mention tuning issues and the fact that it won't run worth a damn. I agree, I wouldn't let the mechanic who gave you that advice touch anything. Quote Link to comment Share on other sites More sharing options...
Beatty89 Posted June 15, 2008 Author Report Share Posted June 15, 2008 Thanks alot guys.. Quote Link to comment Share on other sites More sharing options...
camatv Posted June 16, 2008 Report Share Posted June 16, 2008 holy cow this site is always good for a laugh.. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 17, 2008 Report Share Posted June 17, 2008 Do a trail port or one cylinder and a drag port on the other. Just make sure you have the right pipe for each cylinder. Shearer on the drag ported and a Paul turner Mid on the other. That way you get the best of both worlds. :biggrin: Quote Link to comment Share on other sites More sharing options...
Leadfoot350 Posted June 18, 2008 Report Share Posted June 18, 2008 you could run it that way just make sure the jetting is right for each cylinder and try the two different pipe thing too. The stock cylinder would act like a restricter plate and keep you in check. Too funny Quote Link to comment Share on other sites More sharing options...
sheeblue01 Posted June 18, 2008 Report Share Posted June 18, 2008 Do a trail port or one cylinder and a drag port on the other. Just make sure you have the right pipe for each cylinder. Shearer on the drag ported and a Paul turner Mid on the other. That way you get the best of both worlds. :biggrin: I think he should do one in-frame pipe and one out of frame pipe. Quote Link to comment Share on other sites More sharing options...
