T-daddy Posted June 13, 2008 Report Share Posted June 13, 2008 am i close with my jetting i have fmf pipes air box no lid 280m 25p needle stock air screw 1.5 turns out it starts better after i adjusted the top of the carbs all the way down to bottem out the slides and before i did that it had a back firing on the left pipe but that also fixed it but wen i hit the throttle at idle it bogs a lil bit and then catches temp 80-90 sealevel Quote Link to comment Share on other sites More sharing options...
mopar1rules Posted June 14, 2008 Report Share Posted June 14, 2008 (edited) what fmf pipes and what is the needle clip position at? so far looking a little lean. Edited June 14, 2008 by mopar1rules Quote Link to comment Share on other sites More sharing options...
T-daddy Posted June 14, 2008 Author Report Share Posted June 14, 2008 what fmf pipes and what is the needle clip position at? so far looking a little lean. clip stock fmf gold series Quote Link to comment Share on other sites More sharing options...
poorboy Posted June 14, 2008 Report Share Posted June 14, 2008 clip stockfmf gold series Are you running with air box ? snorkel off? Try turning in the air screw in run it 1 1/4 turns see if that helps Have you done a plug chop? Quote Link to comment Share on other sites More sharing options...
T-daddy Posted June 14, 2008 Author Report Share Posted June 14, 2008 Are you running with air box ? snorkel off? Try turning in the air screw in run it 1 1/4 turns see if that helps Have you done a plug chop? running airbox no lid no snorkle didnt do a plug chop no where to run it wide open Quote Link to comment Share on other sites More sharing options...
poorboy Posted June 14, 2008 Report Share Posted June 14, 2008 running airbox no lid no snorkledidnt do a plug chop no where to run it wide open I think you are close May have to go up alittle on the main jet. Quote Link to comment Share on other sites More sharing options...
mopar1rules Posted June 16, 2008 Report Share Posted June 16, 2008 (edited) so you have the old pipes that only say "gold series" or do you have fattys or sst's....what? you probably have to jump up like 2-3 sizes on your mains. Edited June 16, 2008 by mopar1rules Quote Link to comment Share on other sites More sharing options...
T-daddy Posted June 16, 2008 Author Report Share Posted June 16, 2008 so you have the old pipes that only say "gold series" or do you have fattys or sst's....what? you probably have to jump up like 2-3 sizes on your mains. old pipes that only say "gold series so u tellin me i need to run 300 to a 320 for just pipes and airbox no lid Quote Link to comment Share on other sites More sharing options...
poorboy Posted June 16, 2008 Report Share Posted June 16, 2008 old pipes that only say "gold seriesso u tellin me i need to run 300 to a 320 for just pipes and airbox no lid Yes ........ I have the same set up as you but i run with the lid on........ snorkel off and i run 280 main needle on 3rd clip 1.5 out on air screw. I did a plug chop and i wouldnt dare remove my lid without gong to at least a 300 main jet Quote Link to comment Share on other sites More sharing options...
mopar1rules Posted June 16, 2008 Report Share Posted June 16, 2008 (edited) yes, you'll need like i said a 300-320 main, with your pipes and lid off the airbox. start with 320's though. Edited June 16, 2008 by mopar1rules Quote Link to comment Share on other sites More sharing options...
T-daddy Posted June 16, 2008 Author Report Share Posted June 16, 2008 yes, you'll need like i said a 300-320 main, with your pipes and lid off the airbox. start with 320's though. allright sounds good ill try some 320 and work my way down and see wat happens im gonna run down the block right now and get some there only $2.50 so ill get as many as it takes to get it right ill report back after i install tonight working on the banshee is getting really easy thanks to u guys and the rest of the people on the website and clymers i could take this thing apart blind folded and put it back together just wanna say but ill let yall no how shee comes out Quote Link to comment Share on other sites More sharing options...
mopar1rules Posted June 17, 2008 Report Share Posted June 17, 2008 hell, maybe even try a 330 off the bat, as long as a store is nearby and they are only $2.50 each. Quote Link to comment Share on other sites More sharing options...
