Jetting and adjustments
T-daddy
am i close with my jetting i have fmf pipes air box no lid
280m
25p
needle stock
air screw
1.5 turns out
it starts better after i adjusted the top of the carbs all the way down to bottem out the slides
and before i did that it had a back firing on the left pipe but that also fixed it but wen i hit the throttle at idle it bogs a lil bit
and then catches
temp
80-90
sealevel
so you have the old pipes that only say "gold series" or do you have fattys or sst's....what? you probably have to jump up like 2-3 sizes on your mains.
so u tellin me i need to run 300 to a 320 for just pipes and airbox no lid
Yes ........ I have the same set up as you but i run with the lid on........ snorkel off and i run 280 main needle on 3rd clip 1.5 out on air screw. I did a plug chop and i wouldnt dare remove my lid without gong to at least a 300 main jet
yes, you'll need like i said a 300-320 main, with your pipes and lid off the airbox. start with 320's though.
allright sounds good ill try some 320 and work my way down
and see wat happens
im gonna run down the block right now and get some there only $2.50
so ill get as many as it takes to get it right
ill report back after i install tonight
working on the banshee is getting really easy thanks to u guys and the rest of the people on the website and clymers
i could take this thing apart blind folded and put it back together
just wanna say :thanks:
but ill let yall no how shee comes out
