Face Posted June 9, 2008 Report Share Posted June 9, 2008 Ok, I have a hidakey that I want to install. How hard is it and do I need anything special to make it happen? I know I have all the hardware but is there wires needed, or anything else? Quote Link to comment Share on other sites More sharing options...
hyperlite33 Posted June 9, 2008 Report Share Posted June 9, 2008 Is it just the bracket that goes under the gas tank bolts? If so, just move your key switch to the bracket and run the wires under the tank. Quote Link to comment Share on other sites More sharing options...
Face Posted June 9, 2008 Author Report Share Posted June 9, 2008 Is it just the bracket that goes under the gas tank bolts? If so, just move your key switch to the bracket and run the wires under the tank. No extra wires are needed? I think I have everything but wire. Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted June 9, 2008 Report Share Posted June 9, 2008 Where did you get your hideakey? JasonBanshee on here has em' cheap did you get one from him? Most hide a keys are simple just remove the key settup on the handlebars and run the wires where you are hiding it at. Quote Link to comment Share on other sites More sharing options...
inthemail Posted June 9, 2008 Report Share Posted June 9, 2008 thats about it! Quote Link to comment Share on other sites More sharing options...
njbanshee Posted June 9, 2008 Report Share Posted June 9, 2008 thats what i did. Quote Link to comment Share on other sites More sharing options...
Face Posted June 9, 2008 Author Report Share Posted June 9, 2008 Sweet thanks for your help! Quote Link to comment Share on other sites More sharing options...
