SAVAGE420 Posted June 9, 2008 Report Share Posted June 9, 2008 Soooo, now that i look at my quad i HATE the stupid bulky kill and light switch. Ive looked at the dirt bike style switches but i was wondering where else i could mount these stock switches for a cleaner look and sorta a close reach? I was thinking about mounting it on the upper part of my stem right below the bar clamps for outa the way goodness but still close to reach...any other idears kids? Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted June 9, 2008 Author Report Share Posted June 9, 2008 Heres pics of the setup Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 9, 2008 Report Share Posted June 9, 2008 Since you run lights you pretty much need that switch. But.... you might be able to wire in a WR light switch one side and use a YZ kill on the other.. I've never looked closely to the wiring setup on the WR light switch so I dont know what its gonna take to get it to work. Just something to check into. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted June 9, 2008 Report Share Posted June 9, 2008 I will try to grab you a pict when i get home today, but i have a CR250 kill switch and then got a 2stage toggle from radio shack and wired it to the lights. Drilled a hole in the tank cover and screwed it in there Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 9, 2008 Report Share Posted June 9, 2008 I will try to grab you a pict when i get home today, but i have a CR250 kill switch and then got a 2stage toggle from radio shack and wired it to the lights. Drilled a hole in the tank cover and screwed it in there That is a good Idea. I too have the Honda kill switch. I just used two togle switches mounted to a pice of strap aluminum. The aluminum strap bolts to the back of the fuel tank like a hid a key. The togle switches I got have a ruber cover that goes over the switch to keep water out. josh Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted June 9, 2008 Report Share Posted June 9, 2008 That is a good Idea. I too have the Honda kill switch. I just used two togle switches mounted to a pice of strap aluminum. The aluminum strap bolts to the back of the fuel tank like a hid a key. The togle switches I got have a ruber cover that goes over the switch to keep water out. josh where did you find the rubber cover at? i have been looking for one but cant find one that fits. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted June 9, 2008 Author Report Share Posted June 9, 2008 (edited) Thanx guys ...but im not drilling any holes in these brand new lakers so i guess i will have to find another place to put a switch. Like some of you know..i freakin hate anything electrical so can a back yard guy like me wire it up no proble??? The kill and light switch.? Edited June 9, 2008 by savage420 Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted June 9, 2008 Report Share Posted June 9, 2008 Thanx guys ...but im not drilling any holes in these brand new lakers so i guess i will have to find another place to put a switch. Like some of you know..i freakin hate anything electrical so can a back yard guy like me wire it up no proble??? The kill and light switch.? ahhh stop being a pussy! lol its a tiny hole and the switch will plug it up, then you screw it down and it looks like thats where its suppposed to be. I drilled mine after having them painted and it didnt hurt a thing. The wiring is very simple. I am not electrically inclined by any means, and I was able to do it. It's pretty straight forward Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 9, 2008 Report Share Posted June 9, 2008 if it were me.. I'd check into the WR headlight switch and just wire it for off/high beams. It'd make for a clean look and no cuttin would be needed. I dont think anyone actually uses low beams anyways do they? just a idea.. :shrug: Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted June 9, 2008 Author Report Share Posted June 9, 2008 Ok thanx i will look in to the WR switch :thumbsup: Quote Link to comment Share on other sites More sharing options...
RIPPEN Posted June 9, 2008 Report Share Posted June 9, 2008 Here is what I did with mine.. Kill button.. Key and headlight switch.. I don't like putting extra holes in plastics or anything either but under the seat I didn't think would be a big deal.. Also helps keep some of the water from gettin to them.. RIPPEN Quote Link to comment Share on other sites More sharing options...
sinisterboo Posted June 9, 2008 Report Share Posted June 9, 2008 look thru your vents in your plastic on the sides in front of the gas tank, see that hoop your steering stem mounts too? it is the same size as your handlebars, and you can reach thru the vent to operate the switch. dammit. now my secret is out!! your welcome. saves you from buying anything. Just mount that stock switch right in there. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 10, 2008 Report Share Posted June 10, 2008 where did you find the rubber cover at? i have been looking for one but cant find one that fits. Mine came with my switches. I bought them on ebay and I can find the seller. They look like this. Just do a web search for toggle switch boot. You should just need one that is the same size as the thread on the switch. Quote Link to comment Share on other sites More sharing options...
rubberneck Posted June 13, 2008 Report Share Posted June 13, 2008 I put an xr kill switch on the bars and put 2 of these waterproof kill switches from trailtech in the tank cover like bansheeman did. You could mount them anywhere in a 3/8 hole though. I like where rippen put his. May do that if I go to aftermartket plastics. My tank cover is black and you dont even see these unless you look. Digi cam is broken or i would post pics. check these out they are great. Push on / Push off http://www.trailtech.net/040-LS-B.html Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted June 13, 2008 Report Share Posted June 13, 2008 Hey, thanks for the ideas guys............. :biggrin: Quote Link to comment Share on other sites More sharing options...
