mdhc500 Posted July 7, 2008 Report Share Posted July 7, 2008 the way i did it was look at other peoples on pics on here to get an idea then hacked em. then i wanted them to look a little different then other people's so i rounded the pointed the tips. heres a pic of it lilmegill727- Can you post a looking down pic of your fenders so I can see the lines you took when cutting them? I too am thinking about cutting my fronts... I am getting new plastics anyway... Thanks... Quote Link to comment Share on other sites More sharing options...
lilmegill727 Posted July 7, 2008 Report Share Posted July 7, 2008 lilmegill727- Can you post a looking down pic of your fenders so I can see the lines you took when cutting them? I too am thinking about cutting my fronts... I am getting new plastics anyway... Thanks... heres the pics Quote Link to comment Share on other sites More sharing options...
mdhc500 Posted July 7, 2008 Report Share Posted July 7, 2008 Thanks for the quick response... Did you use a jigsaw or sawsall? Quote Link to comment Share on other sites More sharing options...
trav-99 Posted July 7, 2008 Report Share Posted July 7, 2008 I like the look of full fenders. If you have to cut them just use a chain saw, It all looks the same. i agree, chainsaw them! hahahahahahahhaha Quote Link to comment Share on other sites More sharing options...
lilmegill727 Posted July 7, 2008 Report Share Posted July 7, 2008 Thanks for the quick response... Did you use a jigsaw or sawsall? i used a jigsaw but you can use a sawsall Quote Link to comment Share on other sites More sharing options...
BansheeDan Posted July 7, 2008 Report Share Posted July 7, 2008 i used a jigsaw but you can use a sawsall a rotozip is the tool of choice for cutting fenders.... Dan Quote Link to comment Share on other sites More sharing options...
Black&Red87 Posted July 7, 2008 Report Share Posted July 7, 2008 Ive found that a dremel with a cut off wheel works quite well also. A sawzall or jig saw will bounce the plastic too much and leave alot of clean up on the fenders. JMO Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 7, 2008 Report Share Posted July 7, 2008 Here is my banshee before the 2006 make over. Quote Link to comment Share on other sites More sharing options...
Banshee_Bandit Posted July 8, 2008 Report Share Posted July 8, 2008 I was quit pissed by the looks of them aero killer fenders so just cut them off with a jigsaw and then cut away the uneven rests of the jigsaw massacre away with a sharp knife... Just striped over in a straight line and worked fine for me...perfetto so don`t make a drama out of the whole story lads its just plastics Quote Link to comment Share on other sites More sharing options...
mdhc500 Posted July 8, 2008 Report Share Posted July 8, 2008 Ive found that a dremel with a cut off wheel works quite well also. A sawzall or jig saw will bounce the plastic too much and leave alot of clean up on the fenders. JMO Yeah, I was going to ask if i could use my air grinder w/cutoff wheel? Quote Link to comment Share on other sites More sharing options...
mdhc500 Posted July 8, 2008 Report Share Posted July 8, 2008 jbooker82- Would you mind sharing/showing how you mounted you front shock reservoirs? I am thinking of getting those same shocks... How to you like them? Are they an improvement over stock??? Quote Link to comment Share on other sites More sharing options...
714banshee380 Posted August 13, 2008 Report Share Posted August 13, 2008 jigsaw or a dremel with a cutting tool. pick one up at harbor frieght for cheap. then use some 600 grit to sand em down and get em smooth Quote Link to comment Share on other sites More sharing options...
