bent steering arm
hey all,
i have a bent steering arm (the arm that has the hole for the balljoint) i have re-wheel aligned it but becuase its shorter, at full lock that wheel can turn further and the rim rubs on the lower control arm, this arm is also bolted on and tak welded in place.
You cant buy the arm seperate from the complete hub/stub axle.
can you buy aftermarket ones can you bend these back or do i buy a 2nd hand one and bolt it on and re-tak it.
thanx
OUCH! That peice is cast. You could try to heat it and bend it back, but that would either make it really weak, or just break it trying to do it. I would buy a new one. I'm sure someine on here has one. I personally wouldn't trust bending it back, since it is cast.
yeh thats what scared me :(, you cant buy that arm as a piece yamaha sell the whole hub/stubaxle with the arm hehe how not fair is that.
I just seen that you live in Australia. That sucks. Maybe you can find someone close to you that sells used ATV parts.
yeh theres a shop close by that wrecks bike's and atv's ill call them tommo, it just suks to put an old part on a new bike hehe even if it works :)
thanx man.
Edited by dirtydownunder
