carb and exhaust?
basically i have a cheetah cub kit 68mm bore, 4mil wiseco crank and a f.a.s.t head on the way from jeff at f.a.s.t. i'm currently running a trinity 2 into 1 35mm keihin and fmf gnarlys. it's for trail and mx type riding (midrange) what should i go for?
cost is not an issue
I also have a 421cc motor. I have 2, 35mm Keihin's, with a Boss Racing intake with built in crossover, and it runs and burns great. Unless you ride strictly trail, ditch the 2 into 1. It's mainly for more bottom end. And, I doubt you bought a Cheetah monoblock for trails. As far as exhaust, what are your intentions with the bike? MX, GNCC, Drag?
As far as pipes go, CPI's your best bet.
i ride a bit of everything so a good all-round exhaust for this setup would be better for me than an absolute peak hp drag exhaust. but i ride mainly with 450 dirtbikes so i am a little bit tired of eating roost hence the bump up in cc. i think i will go with the dual 35s. i'm also runnin a shorter swinger but i'm only 160lbs, will i have wheelie issues
Jeff sells them. I don't know if he ships internationally, though. CPI's and Shearer pipes are mostly for top end power. If you want something for all around, I would go with either Toomey T-5's or some FMF's. I have FMF SST expansion chambers with FMF PowerCore II silencers. Good power throughout the entire range. CPI's would give me lots more top end, but I would lose bottom end. I'm debating on switching to CPI's, because of that. They are excellent for racing, though.
