dajogejr Posted June 2, 2008 Report Share Posted June 2, 2008 I have a stock head I no longer need. Ran it on my cub all last year. I have a Chariot Head that works great now. The paint is sandblasted off. Cut for the big bore, 68mm pistons. Shaved and re chambered for alky/race gas. 20cc. Made 185PSI on my 10 mil cub, 500 foot above sea level, .020 base gasket, stock porting cleaned up. It will take the same Oring that you'd use for domes in a Noss or Coolhead, RTV or Yamabond to seal the water jackets. 70 shipped. Add 3% for paypal. Will ship via Fed Ex with tracking number once payment is received. Will have pics up later. Quote Link to comment Share on other sites More sharing options...
flotek Posted June 3, 2008 Report Share Posted June 3, 2008 thats a deal ...free bump Quote Link to comment Share on other sites More sharing options...
01CandyBlue Posted June 3, 2008 Report Share Posted June 3, 2008 thats a deal ...free bump Will it fit a 420 big bore on stock cylinders?? It was running 17 psi domes. I am a little uneducated in the cub area... Thanks!!!! Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 3, 2008 Author Report Share Posted June 3, 2008 Yep..sure will. Quote Link to comment Share on other sites More sharing options...
01CandyBlue Posted June 3, 2008 Report Share Posted June 3, 2008 (edited) Do you no roughly what equivalent dome size that head would be, isnt it the higher elevation the lower compression? I am in utah so quite a bit higher than you, it may be to loose for me. It is right there, you said it was 20cc, may be too loose, Ill ask my builder Edited June 3, 2008 by 01CandyBlue Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 3, 2008 Author Report Share Posted June 3, 2008 You asked if it would fit... That answer is yes. For your elevation...I would get less cc domes, as said...these are 20s... Quote Link to comment Share on other sites More sharing options...
