Top end rebuild?
I rode with a guy Sunday had t5 pipes v force reeds all he did is put 280 mains stock pilot and runs a air box lid no snorkel ran good all day he just kept doing back to back hill climbs and were in trevorton pa not sure about elevation but should be fairly close to yours it was probably 70-80 degrees.
Good luck
It should start with 110 per side
Has about 45-60 hours on .020 first top end rebuild. But it overheated 3 times caused by way to lean main jets. Im at 1400 elevation. And my compression is about 110 in both cylinders. banshee has starting problems. Usually will only start from pull start or push start then its runs excellent. Mods are in sig. Im tired of push starting this thing every time I want to ride it.
to lean on the pilot jet.
