lonestar Posted May 29, 2008 Report Share Posted May 29, 2008 Check out jjandaracing.com makes these niffty hex idle screws. For Keihin carbs. NICE just got a set no more screw drivers or your fingers. 8mm wrench all that is needed. I may even drill a hole on one of the flat spot put a drif pin make like a T-handle. This guy is the same guy that makes the billet drag axles. Go to his web site look under (other stuff) they ain't cheap. Well worth it IMO. Check it out Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted May 30, 2008 Report Share Posted May 30, 2008 Or you can get a metal Idle Screw from Fast for 5 bucks. http://www.farmandsandtoys.com/partdetail.asp?partid=119 Quote Link to comment Share on other sites More sharing options...
lonestar Posted May 30, 2008 Author Report Share Posted May 30, 2008 (edited) I got them from jeff brass idle screws. You still got to use a screw driver. Can't use screw driver on the clutch side carb no room have to use your fingers. (ITS A BITCH) The Hex ones that jj sells you use 8mm open-end wrench Edited May 30, 2008 by lonestar Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted May 30, 2008 Report Share Posted May 30, 2008 Those idle screws are very nice, but a little expensive. I might have to get some though, the plastics ones are a joke. :cool: Quote Link to comment Share on other sites More sharing options...
