shovelhead Posted May 28, 2008 Report Share Posted May 28, 2008 Will a Noss cool head for cub fit on a cheetah motor ( non cub) ?? Quote Link to comment Share on other sites More sharing options...
pabansheematt Posted May 28, 2008 Report Share Posted May 28, 2008 Will a Noss cool head for cub fit on a cheetah motor ( non cub) ?? NO. Quote Link to comment Share on other sites More sharing options...
shovelhead Posted May 28, 2008 Author Report Share Posted May 28, 2008 NO. damn..... thanks Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted May 28, 2008 Report Share Posted May 28, 2008 Will any standard cool head bolt right onto a cheetah or cub? Or do you have to buy one for those cylinder setups? Whats a chettah, and Whats a cheetah cub? Quote Link to comment Share on other sites More sharing options...
NYUK Posted May 28, 2008 Report Share Posted May 28, 2008 rk tech makes a head for cheetas.that`s what i ran on mine. Quote Link to comment Share on other sites More sharing options...
NYUK Posted May 28, 2008 Report Share Posted May 28, 2008 Will any standard cool head bolt right onto a cheetah or cub? Or do you have to buy one for those cylinder setups? Whats a chettah, and Whats a cheetah cub? cubs will accept standard banshee cool heads.and stockers. cheetas are larger and require a specialty head and cr 250 reed cages.. Quote Link to comment Share on other sites More sharing options...
shovelhead Posted May 28, 2008 Author Report Share Posted May 28, 2008 nyuk, do the rk tek heads use domes? or are they just cut for specific applications? did you think your was worth the cost over stock cheetah head? Thanks Quote Link to comment Share on other sites More sharing options...
NYUK Posted May 29, 2008 Report Share Posted May 29, 2008 nyuk, do the rk tek heads use domes? or are they just cut for specific applications? did you think your was worth the cost over stock cheetah head?Thanks yes the rk tech head had changeable domes. did it create a difference. i dunno. it leaked like a spaggeti strainer. i sold it before i really got to use it. Quote Link to comment Share on other sites More sharing options...
FadedDreams Posted May 29, 2008 Report Share Posted May 29, 2008 I have the RK Tech head on my stock banshee cylinders and he cuts the domes for how your motor is set-up and the type of fuel you want to run.You have to use his domes,they aren't inter-changeable like with other brands.And i believe only his o-rings will work too.I had a problem with mine leaking at first when i was using the stock head nuts,but Dan@Patriot Racing gave me some acorn nuts and it fixed that,hasn't leaked since. Quote Link to comment Share on other sites More sharing options...
shovelhead Posted May 29, 2008 Author Report Share Posted May 29, 2008 thanks NYUK & Fadeddreams.. I guess for now I will stick with stock cheetah heads..I don't need any more problems.. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 29, 2008 Report Share Posted May 29, 2008 The big difference is the Cheetah bolt spacing is different and the Orings are on the cylinders instead of the head, actually a MUCH better design than the stock/cub configuration. Acorn nuts and brass washers are a must IMO on any of the aftermarket heads. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted May 29, 2008 Report Share Posted May 29, 2008 so the cub is small bore and the cheetah is big bore then? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 29, 2008 Report Share Posted May 29, 2008 Cubs come in 65mm and 68mm bore. (If you get them coated for nikasil. A SMALL minority get the cast for steel sleeves) Super Cubs come in a 72mm bore. Cheetahs have bores all over the board, starting at 65mm I believe....and go up to 74 or 75mm bore, I think. They have Oringed cylinders and LARGER intakes on them as well. And they have a larger stroke option...too. They were around long before the cubs. Cubs were designed to use stock banshee components, reed cages, pipes, head, etc.... Quote Link to comment Share on other sites More sharing options...
FireHead Posted May 29, 2008 Report Share Posted May 29, 2008 thanks NYUK & Fadeddreams.. I guess for now I will stick with stock cheetah heads..I don't need any more problems.. There really aren't any drawbacks to the original Cheatah heads......... :thumbsup: Quote Link to comment Share on other sites More sharing options...
shovelhead Posted May 29, 2008 Author Report Share Posted May 29, 2008 as always, very interesting & informative info. from you guys.. I thank you Quote Link to comment Share on other sites More sharing options...
