My 06 Won't Start
I bought this bike with 0 hours on it about a month ago. I have about 10 hours on it now. I put DG silencers on it and it ran fine. This weekend it blew a small hole in the in the plastice/rubber joint between where the silencer and the head pipe meet. I put a new joint on and now it will not start. I have spark but there seems to be no gas getting to the plugs. Gas comes out of the percock fine. Any ideas???
Edited by dannysbanshee
The only good advice that I can give to you is, DO NOT USE STARTING FLUID EVER AGAIN!
Check the compression on both sides. Hopefully something didn't give out internally. Also make sure you didn't just foul a plug. You said it's sparking, but are you checking just the wires, or did you check the wires and plugs?
