gregrob Posted May 19, 2008 Report Share Posted May 19, 2008 Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted May 19, 2008 Report Share Posted May 19, 2008 Is that your 4 mill you just built? Quote Link to comment Share on other sites More sharing options...
gregrob Posted May 19, 2008 Author Report Share Posted May 19, 2008 Yep, had about 2hrs on it. I'll get a pic of the spark plug tomorrow, it's custom.... Good news is I just have to order a piston and put it back together. Got off lucky, the bore cleaned up nicely without any gouges, we just honed it and the dome will take some work but I can clean it up too. Quote Link to comment Share on other sites More sharing options...
njbanshee Posted May 19, 2008 Report Share Posted May 19, 2008 thats good news Quote Link to comment Share on other sites More sharing options...
gregrob Posted May 19, 2008 Author Report Share Posted May 19, 2008 (edited) Definitely. I was very dissapointed when that happened. Certainly relieved to find I didn't mess up the new cylinders, crank etc. Carb came out of the boot on the bottom and sucked a bunch of air. Jetting for the other side was a tad rich, piston looked perfect. Thing ran HARD before that happened though, I mean pulled like nothing I have ever been on/in. SOOO much fun! Kevin really does good work. Trying to find just one 795 series piston and get it here by Wednesday/Thus of this week. M&M only has sets of 2 on their site. Edited May 19, 2008 by gregrob Quote Link to comment Share on other sites More sharing options...
BansheeKid15 Posted May 19, 2008 Report Share Posted May 19, 2008 Carb came out of the boot on the bottom and sucked a bunch of air. That SUCKS, atleast its going to be an easy/quick fix Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted May 19, 2008 Report Share Posted May 19, 2008 Damn lucky lucky you well kinda in a way! lol Could have been worse. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 19, 2008 Report Share Posted May 19, 2008 That piston is nothing that a little JB Weld can't fix...LOL... Seriously, when you take the top end off, get some gas and some 20:1 premix of your choice, take the motor out of the frame...and pour the fuel down the crank case on both sides... swish it around, then dump it out. I'd do this three or four times. Some of the metal had to make it down to the bearings... I smoked a piston last year, just rinsed it...no issues... Quote Link to comment Share on other sites More sharing options...
bonbon Posted May 19, 2008 Report Share Posted May 19, 2008 Run it. You should see the left piston in my motor right now. And that aluminum that flew up on the domes just fixed any pits and scratches you had in them. I'd say your carb did you a favor. LOL Quote Link to comment Share on other sites More sharing options...
gregrob Posted May 19, 2008 Author Report Share Posted May 19, 2008 LOL, just throw a hone at it.... Ordering the piston now, should have her back together by midweek. Thanks for the tips daj Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 19, 2008 Report Share Posted May 19, 2008 While you're at it....get several white rags or towels you don't care for. WHen you pour out the gas/oil from the crank case, you'll spot aluminum/metal shavings easier on the white cloth. Use a new one each time, and when the gas/oil coming out from the "flush" appear clean, you're good to go... Quote Link to comment Share on other sites More sharing options...
gregrob Posted May 19, 2008 Author Report Share Posted May 19, 2008 Plugs Quote Link to comment Share on other sites More sharing options...
caddyman Posted May 20, 2008 Report Share Posted May 20, 2008 Whooaa......lol. That is custom..........nice! Quote Link to comment Share on other sites More sharing options...
