astars25 Posted May 11, 2008 Report Share Posted May 11, 2008 alright i need some help..... i redid my banshee i painted the frame, and rebuilt the motor put it back together and no spark. i made sure the grounds that i knew of were clean, the ground on the frame by the cdi and where the coil connects to the frame. still no spark. i put a new stator in still no spark. so i replaced the coil, cdi, and wire harness and all i can get is the lights to light up when i kick it. any one have any idea what this could be... it would be a great help thanks Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted May 11, 2008 Report Share Posted May 11, 2008 Check the gap on your pickup coil, should be .020" Quote Link to comment Share on other sites More sharing options...
astars25 Posted May 11, 2008 Author Report Share Posted May 11, 2008 Check the gap on your pickup coil, should be .020" how do i adjust it if not? thanks Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted May 11, 2008 Report Share Posted May 11, 2008 the bracket it mounts to has 2 phillips head screws, just loosem them and move it closer, use a .020" feeler guage between the pickup and one of the 2 raised blocks on the flyweel. when adjusted correctly you should feel a very slight drag on the guage when you pull it out. double check the clearance on the opposite raised block after you tighten the screws back up Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted May 11, 2008 Report Share Posted May 11, 2008 (edited) you dont have to do all that to adjust the gap, you just bend it on the bracket in and check the gap with the feeler gauge. Edited May 11, 2008 by Snopczynski Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted May 12, 2008 Report Share Posted May 12, 2008 you dont have to do all that to adjust the gap, you just bend it on the bracket in and check the gap with the feeler gauge. That works too. I prefer to move the bracket as opposed to bending it myself. Quote Link to comment Share on other sites More sharing options...
