Banshee partout
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
Got pics of most of the parts would have had more but had to come in to charge the batts.
I tried to upload a few but its saying i used all my attachment space???? anyway i can clear that?
either way i can just email pics to those that are interested
Thanks
Heres a list of parts I have. Price are plus shipping if needed. I accept paypal and Money orders.
Everything will be on ebay next week.
Engine parts
Cases good shape no damage $110
tranny and all internal gears, shift mechanisms etc $110
Oem crank and rods good shape $60
Oem crank needs one lower rod bearing/rebuilt $10
Oem head some buildup on one dome could use cleaned up $15
Cylinders not sure bore ill check on calipers tonight $100 could use hone
Suspension
Front stock shocks purple/pink springs $25 pair
rear shock yellow spring nice shape $45
Oem swingarm $25
A arms good balljoints/boots w/ hardware Oem $90 set of 4
Tie rods w/ ends $25 pair
Spindles $30 pair
Oem carrier and axle $75
rear linkage $10
wheels, brakes etc...
Oem white yamaha wheels 10" front 9" rear $50 for 2 or $85 for all 4 good shape normal wear
ITP wheels like new $100 per 2 or $160 all 4
Complete front brake setup, master, calipers, lines etc $35
Rear master, line, resi, lever $25
Oem steering stem w/ 7/8th clamps $30
Front hubs and rotors $40
Rear wheel hubs $30
Footpegs $5
Stock heelguards metal and black plastic peices $25
Graydon pro line polished nerfs w/ hardware $65
Graydon proline swingarm skid w/ hardware $35
PRM belly skid w/ hardware $35
A arm skids (coveres top and bottom (2 peices each side)) w/ hardware $35
Blue Tag 7/8th bars w/ pad $10
V force reed valves $75 (not sure which model)
Clutch lever assembly w/ cable $10
DG front bumper $30
Pro circuit platinum pipes and pro circuit silencers $180
Complete wire harness w/ components (cdi, coil, etc) $45
Headlight/kill switch $20
Oem airbox w/ filter $20
Carbs tors removed w/ twist throttle and cable $50
Radiator w/ hoses and overflow $45
Gas tank w/ cap and petcock $20
Grab bar w/ taillight $20
White headlights w/ grills $25
Stock bumper $10
Local pickup or meet w/in a few hundred miles of NE ohio
Frame w/ swingarm $200 good shape no cracks, bends etc
White oem plastic full fender uncut very good shape $100
Blue/white CEET seat $45
