ds41 Posted May 8, 2008 Report Share Posted May 8, 2008 (edited) i finally got my quad running, put new brake, bearing carrier, brake rotor, axle nut, sprockets, chain, chain guides sprocket hub, and case saver as well as some new wheels [before] [after] BUT when i was greasing it, it look like maybe the seal might have popped of is this ok?? or what should i do o yeah thank you to everyone that has answered my freaking billions of question, i have NO mechanical or any kind of experience working on a quad till this time and it looks like i might have manageded to pull it together :cool: i appreciate everyones help Edited May 8, 2008 by ds41 Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted May 8, 2008 Report Share Posted May 8, 2008 Bike looks nice! I would undo the axle nuts and loosen the chain so you can slide the sprocket hub over and tap the seal back in with a soft face hammer or use a ball pein with block of wood. It doesnt look like your axle nuts are tight enough either. Quote Link to comment Share on other sites More sharing options...
ds41 Posted May 8, 2008 Author Report Share Posted May 8, 2008 Bike looks nice! I would undo the axle nuts and loosen the chain so you can slide the sprocket hub over and tap the seal back in with a soft face hammer or use a ball pein with block of wood. It doesnt look like your axle nuts are tight enough either. so just go ahead and put the hub in right and maybe that seal will go right back in?? Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted May 8, 2008 Report Share Posted May 8, 2008 You should pull the hub out and tap the seal in straight with something. :thumbsup: Quote Link to comment Share on other sites More sharing options...
ds41 Posted May 8, 2008 Author Report Share Posted May 8, 2008 You should pull the hub out and tap the seal in straight with something. :thumbsup: ill let you know how it goes thanks for your help i appreciate it =] Quote Link to comment Share on other sites More sharing options...
