bansheeman1974 Posted May 4, 2008 Report Share Posted May 4, 2008 well i just put my clutch in from fast, man it is great but still real stiff to pull, has anybody ever used a eazy pull purch is it worth it? well please let me know dont want to waste money thanks Quote Link to comment Share on other sites More sharing options...
rubberneck Posted May 4, 2008 Report Share Posted May 4, 2008 Yes, i have easy pulls on both my bikes and they are nice. I got the perch and lever with a bearing in it from FAST also. Give jeff a call and order them they are nice. Now i have to ask, because it makes a huge diff, but did you lube the cable really well. when i first put the fast clutch in my bros bike, i also installed a new cable at the same time. I grabbed the handle before i lubed it just to check the actuation, and I could barely pull the clutch in. Lubed it up really well and it was 10 times easier. Jeff sells the cable luber kits, and they are a really handy little tool to have. I give a good 5 second blast untill i see lube running out the other end of the cable. I do it after every weekend of riding. try it. Quote Link to comment Share on other sites More sharing options...
BSHEE400 Posted May 4, 2008 Report Share Posted May 4, 2008 i run a magura hydraulic clutch and even with hd springs it's easy to pull, a bit costly though Quote Link to comment Share on other sites More sharing options...
bansheeman1974 Posted May 4, 2008 Author Report Share Posted May 4, 2008 Yes, i have easy pulls on both my bikes and they are nice. I got the perch and lever with a bearing in it from FAST also. Give jeff a call and order them they are nice. Now i have to ask, because it makes a huge diff, but did you lube the cable really well. when i first put the fast clutch in my bros bike, i also installed a new cable at the same time. I grabbed the handle before i lubed it just to check the actuation, and I could barely pull the clutch in. Lubed it up really well and it was 10 times easier. Jeff sells the cable luber kits, and they are a really handy little tool to have. I give a good 5 second blast untill i see lube running out the other end of the cable. I do it after every weekend of riding. try it. thanks ill try that i need one anyways for mine and my girls quad Quote Link to comment Share on other sites More sharing options...
rubberneck Posted May 4, 2008 Report Share Posted May 4, 2008 i run a magura hydraulic clutch and even with hd springs it's easy to pull, a bit costly though i have been really tempted to try one of these just for giggles. I dont see many guys running them, but im sure it has to do with the cost. it makes sense that the pull would be easier just for the simple fact of no friction from the cable running in a tube. Are there any maintenance related issues with these? Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted May 4, 2008 Report Share Posted May 4, 2008 I had a thread about the Magura hydros. I just erased the thread yesterday. But, everybody that had them talked very highly about them. And people that didn't have them, knocked them. A good point was brought up, though. If you don't run the hydrolic line in a good spot, it could melt on a pipe or get snagged on something. And if you're out at the dunes or whatever, the vendors don't carry them. But, you can buy a stainless steel braided line to solve that problem. They're about $20-30. Personally, I plan on buying a Magura with S/S line in the future. I just bought a set of ASV-C5 levers. Believe it or not, the ASV clutch lever and perch actually made my clutch a little easier to pull. And you can also adjust it so the bike doesn't creep forward when in gear. Quote Link to comment Share on other sites More sharing options...
rubberneck Posted May 4, 2008 Report Share Posted May 4, 2008 Who carries the magura line? Was the stainless replacement line a magura product or someone elses? Thanks for any info Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted May 4, 2008 Report Share Posted May 4, 2008 Who carries the magura line? Was the stainless replacement line a magura product or someone elses? Thanks for any info Here's one at RMATV, made by Magura. It's a little more than I thought. They're $54.95. The only thing that I don't like about them, is they ain't coated with clear rubber. So, they might fray or get dirt stuck in them. Maybe you can get it coated for cheap. http://www.rockymountainatv.com/productDet...odFamilyId=8803 Quote Link to comment Share on other sites More sharing options...
Ruko Posted May 4, 2008 Report Share Posted May 4, 2008 (edited) I had a thread about the Magura hydros. I just erased the thread yesterday. But, everybody that had them talked very highly about them. And people that didn't have them, knocked them. A good point was brought up, though. If you don't run the hydrolic line in a good spot, it could melt on a pipe or get snagged on something. And if you're out at the dunes or whatever, the vendors don't carry them. But, you can buy a stainless steel braided line to solve that problem. They're about $20-30. Personally, I plan on buying a Magura with S/S line in the future. I just bought a set of ASV-C5 levers. Believe it or not, the ASV clutch lever and perch actually made my clutch a little easier to pull. And you can also adjust it so the bike doesn't creep forward when in gear. Like he says... I have one and I love it. I got my used off e-bay and the slave cylinder leaked a little, still usable just I had to keep toping up the fluid. I ran it like that for a year then got a new cylinder, since then I haven't had any problems with it. I have the original plastic line and it seems pretty tough so I don't think I would bother getting the braided line unless I actually had a problem. I'd be more conserned about breaking the lever or the master cylinder in a crash. For this reason I carry my old standard lever and cable in my tool box whenever I go out, but I've never needed it so far (knock on wood) :biggrin: Edited May 4, 2008 by Ruko Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted May 4, 2008 Report Share Posted May 4, 2008 do you have to use thier levers on the mag setup? also do they have a bleeder valve for getting air out like a brake or what? They are a pain in the ass when they brake in the dune, found that out the hard way. A guy was riding with us on his KTM dirtbike and he had to smallest crashes and it cracked his open, cost him 200 bucks and that wasnt at the dunes. so his weekend was ruined by basically a nothing crash Quote Link to comment Share on other sites More sharing options...
EastCoast Banshee Posted May 5, 2008 Report Share Posted May 5, 2008 Iv herd great things about them myself and im really tempted to get one. I do know that ASV makes a lever for them as well. Quote Link to comment Share on other sites More sharing options...
MarineNYC Posted May 5, 2008 Report Share Posted May 5, 2008 Cough Cough Pussies Cough UUHHHEEMM Excuse me Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted May 5, 2008 Report Share Posted May 5, 2008 Cough Cough Pussies Cough UUHHHEEMM Excuse me word dogg... word. Quote Link to comment Share on other sites More sharing options...
