caddyman Posted April 19, 2008 Report Share Posted April 19, 2008 Pro's & Cons.... I am going to upgrade my carbs.......and I am trying to figure out what the difference would be if I was to run a single carb..... Mods I have........trued welded crank, stock bore, T5's, V3's, open air box, boost bottle......oh yeah baby! Anyway, carbs and a coolhead are in my very near future........should I run a single, or stick with dual carbs....and what size do you think I should run??? Thanks in Advance guys! Quote Link to comment Share on other sites More sharing options...
rubberneck Posted April 19, 2008 Report Share Posted April 19, 2008 What kind of riding are you doing? If no porting, I would stick with stockers or go to some 28pwks. I dont see the point of a single carb but to each their own. If you are going to do some aggressive porting, talk to your porter to see what carbs he recomends. Quote Link to comment Share on other sites More sharing options...
Leadfoot350 Posted April 19, 2008 Report Share Posted April 19, 2008 If I was going to mod out my banshee again the second thing I would do is porting. First is weld the crank. If you just had those two mods you would really feel a difference!!! best money spent Quote Link to comment Share on other sites More sharing options...
mopar1rules Posted April 20, 2008 Report Share Posted April 20, 2008 i agree with rubberneck. single carb to me seems like a waste. stick with stock carbs or go up to 28mm. Quote Link to comment Share on other sites More sharing options...
Bansheekid07 Posted April 20, 2008 Report Share Posted April 20, 2008 well i think it depends on your type of rideing. i just put one on and had it on the trail for my first ride with it yesterday. i do lots of trails so i need low end and midrange while i was out i noticed a huge difference in low end- mid range and i also got lucky and its jetted perfict. i also have close to the same mods just not the reeds. just my 2 cents Quote Link to comment Share on other sites More sharing options...
differentstrokes Posted April 20, 2008 Report Share Posted April 20, 2008 I like the simplicity of a single carb. Not only is it easy to adjust, but it also cleans up everything around the intake really nicely and makes everything easier to get to. Quote Link to comment Share on other sites More sharing options...
peterlocal22 Posted April 21, 2008 Report Share Posted April 21, 2008 single carb is the way to go if you need more bottom end and if you need to constantly work on your carb, for example mess with the jetting during the differnet seasons. there awsome for trail riding. they also make the motor look alot cleaner like differnetstrokes said. here are some dyno results http://www.bansheehq.com/forums/index.php?...655&hl=dyno Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 21, 2008 Report Share Posted April 21, 2008 stick with dual carbs. thats whats meant to be on there. Quote Link to comment Share on other sites More sharing options...
caddyman Posted April 21, 2008 Author Report Share Posted April 21, 2008 I do alot of fast trails......fire roads, logging roads, shit like that. And dune riding, so it's alot of nearly full throttle riding. Quote Link to comment Share on other sites More sharing options...
IrideA250R Posted April 21, 2008 Report Share Posted April 21, 2008 stick with dual carbs then. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted April 21, 2008 Report Share Posted April 21, 2008 dual 28mm's. Quote Link to comment Share on other sites More sharing options...
LS1Inferno Posted April 21, 2008 Report Share Posted April 21, 2008 Dual, if your WOT alot, it the air flow and fuel can favor one side at times, ive seen it happen, it burt up one side, and also took the rod bearings with it. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted April 21, 2008 Report Share Posted April 21, 2008 Dual, if your WOT alot, it the air flow and fuel can favor one side at times, ive seen it happen, it burt up one side, and also took the rod bearings with it. Your smoking crack! Quote Link to comment Share on other sites More sharing options...
njbanshee Posted April 21, 2008 Report Share Posted April 21, 2008 If or when i get my next banshee i will definitly have the single carb setup. Its much easier on the thumb and you get great throttle responce. I think its a good setup for trails and just playen around. Quote Link to comment Share on other sites More sharing options...
scuba147 Posted April 23, 2008 Report Share Posted April 23, 2008 I have a single carb and have no complaints-- i ride dunes, trails, mud, etc.. Quote Link to comment Share on other sites More sharing options...
