14" marvin shaw hillshooter
will this work with a 10 over link style swingarm?
for the stock hieght running a link the rear should be 13.5 in eye to eye. you could run this with no problems it would just be a little harder to bolt it up becasue it will extend a little too for from the mounts.
It would work. Just need to let a lil PSI out of it and make sure the 14" is going to give you the ride height your looking for. I'm pretty sure 14" is the stock length.. so it would sit similar to if you were using a stock shock.
Becky at yarnell told me they ride great in the dunes. They use a different valving system then the comps and can be adjusted more. And if you want a little better ride they can be converted into coil overs where the comps cant. Can't really comment on first hand experience though.. I've never riddin a hillshooter in the dunes.. only comps.
Edited by Fouledout421
I gotta send my rear shock back this week to get shortened, mine is about a inch to long as well. Screwed up and told em' 13 1'2 instead of 12 1'2...
Good Luck! Yarnell is advertising about a 3 week lead time, but so far it's been 6 for the shock of mine they have. :confused:
