BansheesRock Posted April 16, 2008 Report Share Posted April 16, 2008 I have been looking at the G3 power curve reed valves and was wondering if anyone would recommend this product. What product would you recommend over this one? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 16, 2008 Report Share Posted April 16, 2008 If those are the reed cages by 1dirracing, junk. V Force reeds...all the way. Quote Link to comment Share on other sites More sharing options...
BansheesRock Posted April 16, 2008 Author Report Share Posted April 16, 2008 Yes, those are the one's I'm referring too. They sound convincing on their web site. I think I will set back and let you guy's help lead me in the right direction. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted April 16, 2008 Report Share Posted April 16, 2008 I found that a good set of boyessen Pro series reeds work great on stock and mild motors (and helps keep the price down). If you got more radical motor work or planning on it, then the V-force is the way to go. Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted April 16, 2008 Report Share Posted April 16, 2008 I found that a good set of boyessen Pro series reeds work great on stock and mild motors (and helps keep the price down). If you got more radical motor work or planning on it, then the V-force is the way to go. No question! ^^^^^ Quote Link to comment Share on other sites More sharing options...
BansheesRock Posted April 17, 2008 Author Report Share Posted April 17, 2008 (edited) V-Force it is then! The most popular I see on the market right now is the Delta 3. I have heard that the V-Force 2 reed valves were better than the 3, is this true? Also, since I will be going with the V-Force 3 reed's do I need a spacer as well, if so how thick? Edited April 17, 2008 by BansheesRock Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted April 17, 2008 Report Share Posted April 17, 2008 V-Force it is then! The most popular I see on the market right now is the Delta 3. I have heard that the V-Force 2 reed valves were better than the 3, is this true? Also, since I will be going with the V-Force 3 reed's do I need a spacer as well, if so how thick? VF3's. Someone on here dyno'd a nasty engine with and without a spacer. I think he got .25hp out of it. And that was with a bad ass engine. Most of what I've seen, is people use them only to make their carbs clear the clutch thing-a-ma-bob on top of the engine. (Sorry, brainfart. Just got home from a long night at work) Somebody help me out, I'm tired. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted April 17, 2008 Report Share Posted April 17, 2008 yep.. and you were thinking about the Clutch actuator arm. Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted April 18, 2008 Report Share Posted April 18, 2008 If I remember correctly they are not even making the V-force Delta II's anymore. You can still get the reeds for the cages, but I don't think you can get the cages anymore unless someone stock piled them when they were getting close to the end of their run on the Delta II's and may still have some on the shelves............... Quote Link to comment Share on other sites More sharing options...
brugal Posted April 20, 2008 Report Share Posted April 20, 2008 You dont need the spacers Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted May 5, 2008 Report Share Posted May 5, 2008 Vforce III all the way. Quote Link to comment Share on other sites More sharing options...
awaitedshee Posted May 9, 2008 Report Share Posted May 9, 2008 he mentioned a goof question which is better or how much of a difference is there between the v force 2 and v force 3? my banshee(which the jugs are on their way to herrjugs for the hillshoot porting :biggrin: ) has the v force 2's and i was curious Quote Link to comment Share on other sites More sharing options...
