TM Designworks
gumby6t9
I ordered a case saver and a quick drain water pump from TM Designworks and both came with the wrong size bolts for mounting!
I emailed them a few minutes ago... interested to see what they have to say, if anything...
Here is what I sent them:
Hi,
I ordered a case saver and quick drain water pump cover for my banshee. They are very nice products BUT they both came with the wrong size bolts. The bolts for the quick drain are so small they fell into the tapped holes on the case cover. The bolts for the case saver are so big they don't even fit through the holes in the case saver!! (these bolts are not the correct thread either...).
Nice products but you gotta send the correct bolts with them! Thank goodness the magentic drain plug fit!!!
