Smoking and bogging
I'm working on a 2002 and i cleaned the carbs(took everything apart)thinking they where real dirty.It made a little difference but it still bog at take-off but once it got a quarter of throttle it run better but not 100%.
I'll give you guys what i know about this banshee, inside and out.
1)Its all stock except the pro design foam filter and filter adapter
2)Running 32 to 1 oil-gas
3)New spark plugs(B8ES)
4)200 main jets
5)Stock pilot jets
6)Needles are set in the middle(stock)
7)Pilot air screw are set two turns out
Elevation is 267 above sea level
Temerature is 98.
If you guys need more info, let me know
thanks for your help.
Dirty air filter, low compression, old or improperly mixed fuel, weak spark, carb sync, choke crossover tube, float bowls on opposite carbs??
If that all checks out try turning your air screws out 1/4 to 1/2 turn, you may be slightly rich with that temp.
Changed the fuel, carbs synced, did not have crossover tube but one on, floats are in the correct carbs.
I couldn't do a spark plug chop because of where i live.
The thing i haven't checked was the the sliders to see if they are in the correct carbs, i'll check it plus the other things in the morning.
Thanks for responding.
Found the problem, the sliders where put in the wrong carb.
It has a flat spot at the beginning of the rpms but it hauls ass now.
Maybe its normal for stock banshee because its been 11 years since i rode a stock banshee and forgot
how a stock banshee feels.
Thanks again for your help.
theres a difference in the slides in each carb?? i thought theey were all the same .. what the difference??? can anyone tell me tx sorry for the hijack
