slowblueshee2 Posted April 11, 2008 Report Share Posted April 11, 2008 Just curious what kind of results people are getting out the super cubs. Don't here much about them on here but all the builders advertise that they make more power. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted April 11, 2008 Report Share Posted April 11, 2008 they make about 3-5 more hp and a few ft. lbs of torque over the standard cub on average.. Quote Link to comment Share on other sites More sharing options...
slowblueshee2 Posted April 11, 2008 Author Report Share Posted April 11, 2008 In other words they are not worth the extra headache since you have to bore the cases. Quote Link to comment Share on other sites More sharing options...
banshee332 Posted April 12, 2008 Report Share Posted April 12, 2008 In other words they are not worth the extra headache since you have to bore the cases. yes, plus it takes a different head. if I was going that route I would go cheetah Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 13, 2008 Report Share Posted April 13, 2008 As well as extensive (read...expensive) porting to get them to run better than a cub, box stock they're par or slightly less. You're better off with the cub. Quote Link to comment Share on other sites More sharing options...
slowblueshee2 Posted April 18, 2008 Author Report Share Posted April 18, 2008 How do you guys thinks my ported stock cyl. 4mil. will fair against a 472 supercub that isn't ported? Quote Link to comment Share on other sites More sharing options...
FireHead Posted April 18, 2008 Report Share Posted April 18, 2008 As well as extensive (read...expensive) porting to get them to run better than a cub, box stock they're par or slightly less. You're better off with the cub. Word. :thumbsup: Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 18, 2008 Report Share Posted April 18, 2008 How do you guys thinks my ported stock cyl. 4mil. will fair against a 472 supercub that isn't ported? One way to find out. Race him. Too many variables... Quote Link to comment Share on other sites More sharing options...
Geoff Posted April 19, 2008 Report Share Posted April 19, 2008 yes they do require a decent amount of porting because if I'm correct there the same cast as the cub just a 72mm bore with the studs moved out. So all the port and transfer timings need to be re-adjusted. My buddy runs one here in Oregon built by WK and it runs 3.8 all day on a 3-4 year old chassis. I know of only 1-2 4mil cubs out here that run high 3.9's so the track out here maybe a little slow compared to some others. They do cost more since nothing interchanges from a stocker or a normal cub so thats kinda a turn off. Quote Link to comment Share on other sites More sharing options...
Matt21 Posted April 29, 2008 Report Share Posted April 29, 2008 Had a 7mil supercub and loved it was much stronger than the standard 7mil cub (had one of these too) and made around 8 more hp than standard 7mil cubs built by Redline. Made 125hp at least every pull and I don't remember the torque off hand, I will do a supercub again for sure but in 10mil. Hope this helps... Matt. Quote Link to comment Share on other sites More sharing options...
