Chevyman89 Posted April 8, 2008 Report Share Posted April 8, 2008 I am thinking of putting a set of 450 shocks and a arms on my shee i just do jumping for fun adn trails is it worth if. Quote Link to comment Share on other sites More sharing options...
SoCalinIt Posted April 8, 2008 Report Share Posted April 8, 2008 I think so... Any mod to your suspension is going to be great! The Banshee really lacks in that area. You will notice the difference for sure, but remember... The YFZ450 shocks are stiff. Keep that in mind. Quote Link to comment Share on other sites More sharing options...
Chevyman89 Posted April 8, 2008 Author Report Share Posted April 8, 2008 So if i were to find as set of stock 450 shock and put them on then later on get them resprong and revalved, would that help also what is the cost of doing this. Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted April 9, 2008 Report Share Posted April 9, 2008 I would definitely think so... But, since I could be viewed as having a vested interest in the issue, I'll leave the debating to others. To keep it short, you should notice a definite improvement. Is it the same as a $1200 suspension, probably not, but it is a vast improvement over the stock front end. I've supplied many BHQ members with complete 450 front end kits and pieces to complete the conversion, so if you decide to, let me know and I can set you up with everything you should need. Thanks! - Brian Quote Link to comment Share on other sites More sharing options...
ThE_BaNsHeE_mAn88 Posted April 9, 2008 Report Share Posted April 9, 2008 just remember ha the front end sits way lower with that set up. Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted April 9, 2008 Report Share Posted April 9, 2008 (edited) depends on the price if its real cheap go for it.., but by the time you get the a arms, and shocks, shipped to you, im sure you are lookin at , at LEAST $500 right? the way i saw it was save another $500 and get a front end that is made for the banshee, a arms with the right geometry, and shocks that are built for your , youll be happier in the end that you did, i cant see justifying spending $300 or whatever on a pair of USED a arms that arnt even made for a banshee.., and very weak shit at that, ive personally seen them crumple like soda cans from small crashes that even a stock a arm would shake off, same thing with the shocks, how much are they goin for, 150-200$? i just dont get it,,youd need to spend another $150 or so just egttin them revalved to ride halfway decent, a couple hundred more $ and works will custom build you a set, with re\zies, multi rate springs and be setup for YOU, and they will ride way better, the cheap way isnt always the best way... but then again if you could pickup the whole front end, arms , shocks and tie rods for around $300 or so id do it... anything past that and u may as well save a little money and get some quality Edited April 9, 2008 by Michael Jackson Quote Link to comment Share on other sites More sharing options...
Chevyman89 Posted April 9, 2008 Author Report Share Posted April 9, 2008 just remember ha the front end sits way lower with that set up. I dont know about that cause of my TCS rear shock with the mx set up it sit lower than stock. A fair bit Quote Link to comment Share on other sites More sharing options...
trav-99 Posted April 9, 2008 Report Share Posted April 9, 2008 from the looks of that 450 set-up, those front shocks are gonna coil bind in no time? is there any travel benifit, or gain from the 450 arms? just wondering..... Quote Link to comment Share on other sites More sharing options...
