bada450r Posted April 8, 2008 Report Share Posted April 8, 2008 i want to make my front works a little shorter, where can i send them to?i want like 1 inch to maybe 1 1/2 shorter...thanks Quote Link to comment Share on other sites More sharing options...
SoCalinIt Posted April 8, 2008 Report Share Posted April 8, 2008 Trying to lower your 4mm stock bike? I'd call up Works and order a shorter main spring. I'm sure TCS could do that for you as well. Quote Link to comment Share on other sites More sharing options...
bada450r Posted April 8, 2008 Author Report Share Posted April 8, 2008 Trying to lower your 4mm stock bike? I'd call up Works and order a shorter main spring. I'm sure TCS could do that for you as well. yeah i want to lower my 4 mil.........so just switching springs do the trick?.tanks Quote Link to comment Share on other sites More sharing options...
SoCalinIt Posted April 8, 2008 Report Share Posted April 8, 2008 Yeah... I'd call them up... They are here in the Valley. You could always drive over there and check out different sizes. You might have to re-valve them though. The loss of spring height might put added stress on the valves. Quote Link to comment Share on other sites More sharing options...
trav-99 Posted April 8, 2008 Report Share Posted April 8, 2008 NO !!! !!! ! !! just changing spring WILL NOT work!!! you need to shorten the internal shaft length, install spacers on it, or install a shorter shock eyelet. Quote Link to comment Share on other sites More sharing options...
SoCalinIt Posted April 8, 2008 Report Share Posted April 8, 2008 NO !!! !!! ! !! just changing spring WILL NOT work!!! you need to shorten the internal shaft length, install spacers on it, or install a shorter shock eyelet. Really? I did that to my TCS shocks on my YFZ450 with no problems. The way you listed above whould be more expensive then buying new shocks. The Steelers are cheap, and the shocks are on a drag bike. I think I'd try new springs before I'd buy new shocks, or more expensively completely rebuild. Quote Link to comment Share on other sites More sharing options...
