chris c Posted April 7, 2008 Report Share Posted April 7, 2008 i have t5s and foam filters i jetted them the way it says to but is boggin out from 1/4 to 3/4 what is the best set for this way. n im in sea level n below HELP PLEASE! Quote Link to comment Share on other sites More sharing options...
okbeast Posted April 7, 2008 Report Share Posted April 7, 2008 Probably want to raise the clip on the needle until the bog goes away. You will want it on the 3rd or 2nd position from the blunt end. Quote Link to comment Share on other sites More sharing options...
Erwin8r Posted April 7, 2008 Report Share Posted April 7, 2008 Airbox? Stock carbs? What main jet? Pilot jet? I have T5's with stock carbs, no air box, running K&N's with Prefilters. I am using 290 mains, 27.5 pilots, and the needle is on the third clip (a little richer) from the top... Unless your main jets are huge and you're soaking your plugs, bogging can be because its lean on the needle... Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted April 7, 2008 Report Share Posted April 7, 2008 (edited) on my bike, their recommendation of 4th clip down was too rich, i moved it up one to the 3rd, and it made a big improvement in low end bog,i doubt the 4th clip is to lean, if anything itll be too rich,your gona have to try yourself and see what works best for you though, only chnage one thing at a time, this is their toomey needle i am talking about by the way Edited April 7, 2008 by Michael Jackson Quote Link to comment Share on other sites More sharing options...
chris c Posted April 8, 2008 Author Report Share Posted April 8, 2008 thanx guys i will try these out 2da after i get out of work. im new in the bansheehq but ive been riding 4 10yrs, now i have the banshee but not as hooked up as the old mods that i had on it so i am starting fresh n also i have a 2005 yfz450. the mods i have on that is a slip-on(Dr.d) rejet carbs n tag fatbars w/ riser Quote Link to comment Share on other sites More sharing options...
