how rich am i
Ryda85
Those pics don't mean anything...
Here's how to tell if you can lean the main out or not...those plugs could be rich on the needle, lean on the mains, vice versa...etc.
http://www.dfn.com/benkaren/plugchop.html
so in order to find out how lean u are, u need to run the bike wide open then kill it, you cant just start the bike and pull the plug and take a pic... get a good run in 6th, then kill it and see what it is, should look like card board
Looks rich to me. Do a 6 gear all shee's got and kill the ignition and coast it in. Pull the plugs and refer to the chart below. give new plugs a 20 minute run in first at moderate loads then do the 6 gear pull.For quick reference jetting inspections, inspect the thread flat around the circumfrance of the plug shank body, cardboard color is perfect. Note: some blends of fuel will distort the color from the typical cardboard color, Octane boosters will as well...The main thing is you NEED some color around the circumfrance of the shank or you are near the toasted engine stage...Jim
http://i57.photobucket.com/albums/g215/pas...e/plugchart.jpg
Edited by PassionRE
yea i think its a little rich based on what jim told me on the phone.....i will do a 6 gear pull this weekend and report back.......br9es's on the stroker jim?
Nope, 8's are fine
