Exhaust Options?
Colby
ASK WHOMEVER is building your motor...
There is a HUGE debate on which pipe is best for which application.
It used to be 4mil or smaller, small bore, larger than 4...big bore. That's not the case. Some stock stroke and 4 mils run very well with big bore, some 10 mils run great with small bore.
So...go on the advice of your builder.
No mods necessary, you'll just have to figure out how to hang the pipes from your footpeg(s). I use a stock front pipe hanger, and you want a rubber mount, NOT solid. They need to flex.
