ds41 Posted April 2, 2008 Report Share Posted April 2, 2008 I recently popped the chain, and i had no case saver and this is a result, nothing is leaking, or anything its just that top piece that is gone what could i do? or how should i fix it Quote Link to comment Share on other sites More sharing options...
pate Posted April 2, 2008 Report Share Posted April 2, 2008 i would try some silicone or something high temp. Quote Link to comment Share on other sites More sharing options...
bansheejoel Posted April 2, 2008 Report Share Posted April 2, 2008 If it was me i would use jb weld. I know a couple of people that have cracked their cases and they leaked gear lube and jb weld sealed it up and they never had a problem with it. Quote Link to comment Share on other sites More sharing options...
pate Posted April 2, 2008 Report Share Posted April 2, 2008 ya jb weld would work great also. Quote Link to comment Share on other sites More sharing options...
ds41 Posted April 2, 2008 Author Report Share Posted April 2, 2008 nice ill go ahead and go with some JB weld, what about a chain? whats the best chain and how many links would it be if its stock swing arm 14t front and 41 t back Quote Link to comment Share on other sites More sharing options...
pate Posted April 2, 2008 Report Share Posted April 2, 2008 go to ebay u can get sprockets and chain together for like 65.00 to 80.00 and u get get them in colors. they are good chains and sprockets. Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted April 2, 2008 Report Share Posted April 2, 2008 YA, I'd JB Weld it to start with and see if that fixes it if it's not leaking anything......... Quote Link to comment Share on other sites More sharing options...
pabansheematt Posted April 2, 2008 Report Share Posted April 2, 2008 I recently popped the chain, and i had no case saver and this is a result, nothing is leaking, or anything its just that top piece that is gone what could i do? or how should i fix it The damage is already done. J.B. weld will do nothing but make it look a little better. as long as theres no leaks, let it go. Another idea is to trim the busted area with a die grinder, you could make it look better, ( less noticable) I've done this to a few bikes in the past. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 3, 2008 Report Share Posted April 3, 2008 go to ebay u can get sprockets and chain together for like 65.00 to 80.00 and u get get them in colors. they are good chains and sprockets. There is no way I would skimp on the chain. If you get one off of ebay buy a good chain not a no name brank. Quote Link to comment Share on other sites More sharing options...
98_shee Posted April 3, 2008 Report Share Posted April 3, 2008 PM ls409 he can weld them Quote Link to comment Share on other sites More sharing options...
Screaming Yellow Zonker Posted April 3, 2008 Report Share Posted April 3, 2008 you can get some good parts through F.A.S.T. X-ring chain and gears. do not skimp on the chain. Quote Link to comment Share on other sites More sharing options...
Leadfoot350 Posted April 3, 2008 Report Share Posted April 3, 2008 I would grind it flat before anything. Thats a big hole to just put jb weld on it. Try to get a thin piece of alum to cover the hole then jb weld around it. Or you could just have someone weld it but I dont think its going to need it because there is not much pressure in the gear side. Either way it makes me happy to have a case saver! Quote Link to comment Share on other sites More sharing options...
Dick Wheels Posted April 3, 2008 Report Share Posted April 3, 2008 lol thats nothing! i should post a pic of my case. The chain went on the previous owner and took everything clean off. It dosent leak and the stator side is all good but took off all the mounts around the sprocket Quote Link to comment Share on other sites More sharing options...
Twistedtrik Posted April 3, 2008 Report Share Posted April 3, 2008 We weld cases all the time in our shop. Not a huge deal to do. Any good GTAW welder can fix it and make it unnoticeable. Quote Link to comment Share on other sites More sharing options...
ls409 Posted April 3, 2008 Report Share Posted April 3, 2008 hi my name is tood d messer if you want them welded up its not that big of a job you can call me or email me you send me you cases and ill weld them for 65 +ship back cost sandjunkie72753@yahoo.com 14798463668 is home thanks ls409 Quote Link to comment Share on other sites More sharing options...
