cbarown Posted April 2, 2008 Report Share Posted April 2, 2008 So I bought an 05 of a guy a few eeks ago brought it home it was running kinda rough so i figured bad jetting or dirty carbs so i brought it to a guy who kows a good amount about banshees, he has owned several. he went through it found a good size piece of dirt in the carb. also he said the right bank is detinating. he said it could be caused by a bad seal int he crank area he also said it would be a good idea to switch the stock air filter and housing to a k&n. what do you guys think of this Quote Link to comment Share on other sites More sharing options...
shee4speed Posted April 2, 2008 Report Share Posted April 2, 2008 Sounds good. How's the bike run now after cleaning the carbs? Quote Link to comment Share on other sites More sharing options...
brugal Posted April 2, 2008 Report Share Posted April 2, 2008 Sounds bad.Depending on the crank seal,you might have to split the cases. Quote Link to comment Share on other sites More sharing options...
cbarown Posted April 3, 2008 Author Report Share Posted April 3, 2008 Sounds bad.Depending on the crank seal,you might have to split the cases. still running roughi think its gonna turn out being one of the crank seals. Quote Link to comment Share on other sites More sharing options...
