Pardee208 Posted April 2, 2008 Author Report Share Posted April 2, 2008 it runs, but it dosnt run like it use to before i removed tors, its just very boggy and no power im going to put in some 300 mains today and see if that helps. on the tors. does anyone know forsure that any wires need to be tied together or not?? Quote Link to comment Share on other sites More sharing options...
05Special Posted April 2, 2008 Report Share Posted April 2, 2008 I just put a single carb on and all i did was cut the wires from the sensor on thr throttle housing itself, unplugged the box, and unplugged the carbs. I didn't tie anything back together..Runs great, is it running on both cylinders? I would just check all the electrical connections and make sure eveything is clean and tight. Quote Link to comment Share on other sites More sharing options...
dragbanshee Posted April 3, 2008 Report Share Posted April 3, 2008 it runs, but it dosnt run like it use to before i removed tors, its just very boggy and no power im going to put in some 300 mains today and see if that helps. on the tors. does anyone know forsure that any wires need to be tied together or not?? You PCd the frame, took the tors off so you had to drill for idle screws and re sync carbs, did everything go well with changeover? Its probably one of the two things: make sure you have good grounding or carbs arent sync, maybe shavings / pilots clogged. Im pretty sure I did not tie any wires together either. Good Luck! Quote Link to comment Share on other sites More sharing options...
ziegman Posted April 3, 2008 Report Share Posted April 3, 2008 Slides are in backwards. Make sure choke crossover tube is in place between the carbs Quote Link to comment Share on other sites More sharing options...
Pardee208 Posted April 3, 2008 Author Report Share Posted April 3, 2008 Yes everything you guys said is all checked good. I put in some 310 mains today and she runs! almost getting there. the bottem end is rich so i raised the needle up 2 notches, Im think i got it, but i cant run it because i need some rubber hose to connect the stock silencers to the T5's, thats tomarrows goal though. but i am going to check all my grounds. and chip off the powdercoat to establish a good connection. Thanks for all your input guys! heres a pic of the pink thing.(remember boys, women ALWAYS get what they want!) lol Quote Link to comment Share on other sites More sharing options...
