TZ Max load bearing needed?
gregrob
Here's the crank I'm looking at http://webforce.nwrain.net/founder/cascade...&search=4mm
The one without the TZ bearing is 100 cheaper, are you guys running them right out of the box, or with the TZ bearing? Bear in mind I'm up here at 6-8K feet so I'll be making significantly less power than you dudes at sea level.
Also it says "This crank is trued & welded inside and out". Is that something additional that cascade does, or is it just the standarh hot rods fare?
Thanks a lot
Welded inside and out is something they do. Standard 4 mil hot rods crank come with a weld, but they're shitty ones...and most builders will tell you they need to be rewelded.
TZ bearings are the best. Here's the deal...and I'm letting the secret out of the bag.
OEM Yamaha TZ bearings are no longer made, and they are becoming harder and harder to find.
What a lot of people are doing are buyin NTN brand bearings that are The same design and style of the OEM yamaha bearings, cutting a groove in the outer race, and calling them TZ bearings.
Even crankworks carries and sells NTN brand bearings but calls them TZ.
So, IMO...is it worth it? yes...I've yet to see a TZ bearing fail. however, the maxload bearing that Jeff @ FAST carries is also a very, very nice bearing for quite a bit less money...
You're paying for a quality part, and insurance...so...how much is that worth to you is the question.
Thanks a lot
Greg give us a call as we have cranks (that are Rewelded for strength) on hand with your choice of bearings, couple of days closer to you, and alot cheaper.
Thanks for the input guys.
I'll give you a call to discuss Jeff. Still figuring and making sure I'm gonna have the funds to go 4mil, but with me already getting porting, buying pistons, and bigger carbs, I figure this is the perfect time.
Instead of doing everything twice, have the cyls setup for a 4mil, get 4mil pistons / domes, and be done with it.
Thinking ahead usually puts you ahead (I think I might coin that phrase...LOL)
A stroker crank and good porting to match will make a BIG difference, one you'll be happy with.
Cool.
What kind of numbers you think it would throw down on a dyno with an "aggressive" dune port?
It's always hard for me to guess being up here over a mile high :blink:
would be 33pwks more than likely, with the 4mil and other mods in my sig
not sure but i tought that tz bearings work better with straight cut gears....do to the side load that the stock gears put on the crank since the tz bearing is a floater bearing the stock gears just dont work as good....like i said not sure
