Bobby Banshee Posted March 23, 2008 Report Share Posted March 23, 2008 (edited) Here's a few things that have been added to the bike. Kevin Herr did all the motor work. All this has been added to the bike with about 30 miles on it. Need 4k for the bike. $200-Gas Tank 5.5gal. $228- yzf450 Shocks $89-K&N Air Filter Lid $90 K&N Box Filter $100-Trail Tech Computer $106-Trail Tech Mount $175-Billet Aluminum Intake with cross over tube $80-Billet Aluminum Kick Starter $23-Billet Aluminum Dip Stick $60-Billet Aluminum water pump $389-7pc Billet Aluminum Kit all chrome $90-High Rev CDI Box $198-V Force 3 Reed Valves $18-Stainless Bolt Kit $185-Ricky 200watt Stator $53-New Steering Stem $21-New Rear Bearings $18-Steering Stem Bearings $60-4 Tie Rod Ends $110-Front Bumper $110-Body Skid Plate $33-Gear Shifter $30-Radiator Grill $64-Twist Throttle $85-Swing Arm Skid Plate $89-Chain/Sprockets $80-Fat Bars $225-Razor Tires $50-Carb Jets $250-Chrome Clutch Cover and Polished Cylinders $10-Aluminum Block Off Plate $27-Perch&Lever $27-Modquad Case Saver $1495-Motor(Vito 4 mil crank, aggressive trail/woods port on cylinders, cool head, pistons 100 over). Total_$4868 Edited March 23, 2008 by Bobby Banshee Quote Link to comment Share on other sites More sharing options...
blanco25 Posted March 23, 2008 Report Share Posted March 23, 2008 Did you get the some of that chrome from the duneraider on ebay? I have the same looking stuff. If it is, it is good chrome. Quote Link to comment Share on other sites More sharing options...
Bobby Banshee Posted March 23, 2008 Author Report Share Posted March 23, 2008 Did you get the some of that chrome from the duneraider on ebay? I have the same looking stuff. If it is, it is good chrome. I ordered all the billet and had it chromed. Quote Link to comment Share on other sites More sharing options...
