okbeast Posted March 11, 2008 Report Share Posted March 11, 2008 Never jetted anything other then a stocker carb, so lookin for a good starting place here. Gonna put some 34pj's on this weekend. Got a strong dune port, T-5's, coolhead w/ 20cc domes, k&n pods. Elevation is around 1200 ft., temps are around 70 right now. Just looking for somewhere to start since I've never even messed with these carbs. Quote Link to comment Share on other sites More sharing options...
r_flagel222 Posted March 11, 2008 Report Share Posted March 11, 2008 Never jetted anything other then a stocker carb, so lookin for a good starting place here. Gonna put some 34pj's on this weekend. Got a strong dune port, T-5's, coolhead w/ 20cc domes, k&n pods. Elevation is around 1200 ft., temps are around 70 right now. Just looking for somewhere to start since I've never even messed with these carbs. i just got throught jetting mine... wesw helped me! i started with 150 mains, 52 pilots, and cel needles on middlle clip position with idle knobs out 9 full turns and air screw out 1.75 turns. it was a little fat to start but thats what you want to start with... good luck and by the way, wesw is the resident expert here, if you do a seach for his posts he has many pj walk throughs... Quote Link to comment Share on other sites More sharing options...
okbeast Posted March 17, 2008 Author Report Share Posted March 17, 2008 well got some on and rode it today. ran pretty damn good. i do need to change the jets up some though. it's got 155 mains and 48 pilots. i KNOW the pilots are way too big, it bogs just a tad everytime i start it. what would be a good (better) pilot size? its just a dune ported stocker w/ t-5's, soon to be shearers i think. Quote Link to comment Share on other sites More sharing options...
kawiking Posted September 6, 2008 Report Share Posted September 6, 2008 i need help with a 34pj set up.... we are 300 above sea level.. 19 domes ,clean up port(stock juggs),cpi inframe pipes. 160 main, stock needle, stock pilot. feels fat on top, but changed jets and hasnt helped..... cmon wes..lol Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 6, 2008 Report Share Posted September 6, 2008 Kawi try a 155 main What needles do you have in it now. I would recomend cek's middle cip with 50 pilots. You really need a carb sync tool to set up the idle. That way you get them set the same. I found that my PJ's usually run a size or to larger on the pilots compaird to PWK's. I ran a 52 pilot with PJ's when I switched to PWK's on the same motor I ended up at 48. PJ's must like a little richer bottom end, maybe they dont pull as much fuel down low so they need richer settings. Same reason for the CEK's with the PJ, vs the CEL for the PWK. CEK is a little richer on the bottom end. Quote Link to comment Share on other sites More sharing options...
kawiking Posted September 6, 2008 Report Share Posted September 6, 2008 its my old set up on my buddies shee.... it has the stock needle in it.. not dure what it is. it pulls hard on bottom but breaks up on top end... i had the set up on my fmf's and it would tear 4 stroke bolt on bikes up.. it would beat my buddies 686 craycraft bike... are friends raptor with a 12:1 piston and barkers is barely beating it.. and the 686 rap will smike that rap... so the shee's not runnin like when it was in my bike... just not pullin hard on top... what is the stock pj needle Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 6, 2008 Report Share Posted September 6, 2008 CEG If it is running good on the bottom end then just try droping the mains. I would say 160 is plenty rich for a stock cleaned up port. Quote Link to comment Share on other sites More sharing options...
kawiking Posted September 6, 2008 Report Share Posted September 6, 2008 well since the cpi s are a drag pipe, how is that goin to effect the jettin ? Quote Link to comment Share on other sites More sharing options...
kawiking Posted September 6, 2008 Report Share Posted September 6, 2008 my buddy said he went to a 148 and same thing.... Quote Link to comment Share on other sites More sharing options...
