whats next
bansheedunner
i have a slightly modified banshee, and i am wondering what the next step would be to turn it into a fun dunner drag bike, her are the mods that are done so far. 19cc domes/cool head/weisco pro light pistons/ timming advanced degree key/ pro circit plat pipes/ jetted/ tors remove/ air box removed/ dune/drag port/ 55 to 60hp i would like to step up to 70hp or more!!!!
whats done to the frame? what size swingarm? you still running the bumpers and cup holders? drag port DYNA ignition, ditch the advance key, nology coil alky carbs.. override transmission locker for the clutch 11 or 12 paddle hauler SLS 73 or 74 roll out tires. 6-8 over swingarm cut everything off the frame marvin shocks and lighten er up!
  • 2 weeks later...
I would go with vforce reeds and a good set of in frame drag pipes. If you have more money get the biggers carbs intake boots and pod filter with outer wears. Then get a longer swingarm. Tires are very important too. By the time you finish this you will probably need a rebuild. Then go big. stroker, cubs, drag ported, lockup clutch, dyna ignition and an override tranny. Along the way you can get rid of all the extra weight on her. By the time you buy all that you are better off buying a nice bike in the for sale section of this site. You would save atleast 50%.
No shit! I wish I would have done that on my past three builds...
421 duner... Too much money!
370R stock frame hill bike... Way too much money!
14mil Cub in a +10 hill frame... No even going to comment!
Yep. Me too.
