Parting out 01 Banshee
  • Replies 78
  • Created
  • Last Reply
Top Posters In This Topic
Ok got everything tore down and made up a list of everything. I have pics of most of it also. Prices are what id like to get but im negotiable. All is + shipping to your zip. If you buy a few things ill make package deals/discounts.
Located in NE ohio if close feel free to come by and pick up, maybe able to meet up if needed w/in cpl hundred miles for gas on bigger parts
Engine parts:
01 motor bottom end, crank bearings seized. Good tranny, goes through gears, good clutch side covers, kicker included, Left case has the normal banshee chunk missing from chain smacking it, but its just on the lip nowhere where it would cause leaking problems or anything other than cosmetic.
I havent removed the topend yet to check the cylinders but i was told they were fresh (under 10hrs) wiseco .20 over bore. Also has Pro design Cool head in good shape. $550
??year bottom end Crank bearings seized, has clutch, good tranny, kicker, sidecovers etc complete. No case damage. $250
Cylinders no gouges or deep scratches pretty sure stock bore $150
Stock head $25 one dome has some buildup needs cleaned.
Stock carbs $20
stock carbs complete $35
Radiator w/ hoses, cap $50
Dg full pipes $75
Reeds w/ cage $15
Electrical
Complete Wire harness w/ components coil, cdi etc $30
Headlight switch $20
Ignition switch w/ key $15
Headlights $25 (pair)
-- Frame $200 painted lime green, all threads are good, looks to be straight, no cracks or damage that i noticed. Bill of sale
-- chrome Front bumper ? not sure brand? $20
-- chrome Grab bar $15
-- Black/blue seat w/ pan, foam, cover, latch gripper material center blue sides $35
--Rear wheel hubs (pair) $25
--Thumb throttle w/ cables $20
-- Stock axle $40
-- Steering stem $40
--spindles (pair) $30
-- stock footpegs (pair) $5
-- Rear brake hub w/ rotor $20
-- Front wheel hubs w/ rotors $40
-- Rear brake master cylinder w/ lever and resi$25
-- Rear brake caliper w/ lines $30
--Front brake calipers w/ lines hard and rubber $40
-- Front master w/ lever $20
--Front oem wheels straight, normal trail scuffs and nicks on lips $55 (pair)
--Front ITP wheels (thick aluminum) some nicks on lips, hold air and straight $70 or with 50-60% maxxis razr 21" $85
--Rear oem wheels normal trail wear on lips $65
--stock front shocks $15
-- Rear shock $25
--clutch lever perch and cable $15
--Plastics Blue race cut fronts, stock rears, no cracks w/ tank cover and rad cover $80
--Rear sprocket 41t w/ hub $10
--Gas tank w/ cap and petcock $25
--Swingarm w/ carrier (good bearings) $55
--Rear shock linkages $10
--A arms good balljoints on all right lower has dent, still looks to be straight but pretty good dent on bottom $50 for all 4
--tie rods w/ ends $20
do you have any pics of the ??year cases?
yep have pics of pretty much everything. I have a sale pending for it monday im supposed to meet up w/ the guy, but if it falls through Shoot me your email and ill send you some pics incase, it says i cant upload any more pics. I guess i used to much space lol
thanks my email is acrust00@excite.com
