pasedogg Posted March 5, 2008 Author Report Share Posted March 5, 2008 sweet Quote Link to comment Share on other sites More sharing options...
98_shee Posted March 5, 2008 Report Share Posted March 5, 2008 You can get them here: http://www.thunderproducts.com/thunder_powerjet.htm wish i would have seen these ^^^ before i bought mine i like those better :biggrin: They also have the dial a jet. I have been reasearching these for a few days. I live in UT and experiance a lot of temp changes so I am going to give them a shot. I am just trying to decide on the power jet and dial-a-jet. Quote Link to comment Share on other sites More sharing options...
pasedogg Posted March 7, 2008 Author Report Share Posted March 7, 2008 my buddy says the power jets are hard to dial in and finiky.im new to jetting, should i just get normal standard jets. what should my carb settings for jets, clip, etc be for a 99 stock banshee, DG pipes, stock silencers, uni air filter, closed lid, my elevation is around 350 meteres(not feet) above sea leval.TORS removed Quote Link to comment Share on other sites More sharing options...
pasedogg Posted March 8, 2008 Author Report Share Posted March 8, 2008 bump Quote Link to comment Share on other sites More sharing options...
RedStrapperRacing Posted December 7, 2009 Report Share Posted December 7, 2009 This is an old post but wanted to see what you guys take was - Power Jet or Dial a Jet? which is better? and is it even worth the time on 30mm D-slide carbs? Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 7, 2009 Report Share Posted December 7, 2009 ................. well, do you need the atmospheric self adjusting that bad? if you are happy with just reaching down, then you can go alot cheaper with packards.......just ask wildcard about what you need....basically it's so you don't have to change main jets....and they are good for any carb. Quote Link to comment Share on other sites More sharing options...
RedStrapperRacing Posted December 9, 2009 Report Share Posted December 9, 2009 ................. well, do you need the atmospheric self adjusting that bad? if you are happy with just reaching down, then you can go alot cheaper with packards.......just ask wildcard about what you need....basically it's so you don't have to change main jets....and they are good for any carb. packards? couldn't find any info on them....... Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 9, 2009 Report Share Posted December 9, 2009 just ask wildcard about powerjets.......brandon or shay will hook you up, or suggest what you should go for to fit your needs/wants, and not push anything else on you....or go look on their site, or sposor pge..... Quote Link to comment Share on other sites More sharing options...
