clutch rod
Well, I had the dreaded ball weld it's self to the rod. now it won't come out. it moves freely as I can stick a screwdriver up againsed it and pull the clutch lever and it moves easily. Just won't come out. I've tried a magnet and one of those jaw grabber tool. the jaws will grab it but the rod just only slide so far. Any ideas on getting it out? thanks
-Josh
-Josh
i'd say yours will fall right out from the other side when you get the cases split
It sucks but you are most likely going to have to split your case and pull it out from the other side. This is what mine looked like when I had to take it apart to replace the crank.
Crappy pic but you can sorta see how the end of the rod is mushroomed over the edges of the inner race of that bearing
This is what my actuator looked like
Edited by tgbanshee
That arm is exactly what mine looks like. I'm splitting the case this weekend. Should be put back together by Sun. Just gotta get another arm. Already got the rod, ball, and a cascade clutch adjuster w/pancake bearing. Thanks for all the help guys. So much for my X/C race next weekend. :sad: Can I grind down that arm and re use it if my new one does not come in before the race? Or will it fuck somthing up? I figure i would just need to tighten the adjuster bolt on the pressure plate. But IDK. May call jeff after school today.
We keep all that on hand, give a holler... I never did hear from you last week...?
