BOWTIEKV23 Posted February 23, 2008 Report Share Posted February 23, 2008 This may have been answered before but could use some help on this any opinions would help. This is a fun/trail/mx used shee. Its a 68mm setup using the stock crank. What size carbs should i use ive been told 34s and as little as stock. just want to get a nice tune out of it not looking for insane power just to run nicely. Thanks Kevin Quote Link to comment Share on other sites More sharing options...
Fireroad Express Posted February 23, 2008 Report Share Posted February 23, 2008 30's or 34"s depending if you have any porting done. with a dune port i'd go for the 34's. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted February 23, 2008 Report Share Posted February 23, 2008 28pwk 33pwk 35pwk / airstryker All would be good carbs. The smaller the carb, the better your throttle response will be, and the bigger you go the more top end you get. I wouldn't go any bigger than a 35 on that small of a setup. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 24, 2008 Report Share Posted February 24, 2008 i would run keihin pwk 33's. Great middle sized carb. Quote Link to comment Share on other sites More sharing options...
sled Posted February 24, 2008 Report Share Posted February 24, 2008 28s maybe 30s. they have really small transfers like i said before. Quote Link to comment Share on other sites More sharing options...
