BOWTIEKV23 Posted February 22, 2008 Report Share Posted February 22, 2008 i have a 68mm big bore and probably going to be putting DMC Aliens on. what carbs should i use? thanks for any help that can be provided. Quote Link to comment Share on other sites More sharing options...
IrideA250R Posted February 22, 2008 Report Share Posted February 22, 2008 I would run 35mm Keihin PWK's Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 22, 2008 Report Share Posted February 22, 2008 What type of porting? drag PWK 35's. Dune PWK 33's. Play / Trail PWK 28's or stock carbs. Drag or Dune port will run 10x better with CPI Pipes. Quote Link to comment Share on other sites More sharing options...
BOWTIEKV23 Posted February 22, 2008 Author Report Share Posted February 22, 2008 its more fun/mx/trail. i just didnt think i could get the stockers to flow enough. Quote Link to comment Share on other sites More sharing options...
sled Posted February 23, 2008 Report Share Posted February 23, 2008 What type of porting? drag PWK 35's. Dune PWK 33's. Play / Trail PWK 28's or stock carbs. Drag or Dune port will run 10x better with CPI Pipes. you cant go big with porting on Big bores. i talk to Kevin from HJR on this, the transfers are to small. thats why i didnt use them. i think this thread would do better in the mods section and not the jetting. Quote Link to comment Share on other sites More sharing options...
jmd0346 Posted February 23, 2008 Report Share Posted February 23, 2008 you cant go big with porting on Big bores. i talk to Kevin from HJR on this, the transfers are to small. thats why i didnt use them. i think this thread would do better in the mods section and not the jetting. I dont think you're reading that back right. I dont see how a boring would effect transfer ports that you are going to change anyway when porting. To the OP. You should try some 30m OKO's. Its a kehien(sp?) knock off. Very good carb IMO. I would also go with DMC 916's in stead of the Aliens. Just my opinion. I think the 916 setup looks better and sounds better. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted February 23, 2008 Report Share Posted February 23, 2008 I dont think you're reading that back right. I dont see how a boring would effect transfer ports that you are going to change anyway when porting. He read it right. 66.5 is the biggest you can go on STOCK cylinders, if this guy is running 68mm big bore, he is getting the cylinders resleeved. And he's right...on stock cylinders, that really cramps the transfers..... He's not just boring, it's new (bigger) sleeves as well! Quote Link to comment Share on other sites More sharing options...
