bansh4mil Posted February 19, 2008 Report Share Posted February 19, 2008 does anyone run a case saver with a 15 tooth front sprocket? And if so what brand is it? Thanks Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 19, 2008 Report Share Posted February 19, 2008 does anyone run a case saver with a 15 tooth front sprocket? And if so what brand is it? Thanks Almost all case savers allow you to run 1 tooth bigger in the front than stock. Stock is 14 so you should be ok. Get a TM Designworks, they are the best. Quote Link to comment Share on other sites More sharing options...
yamaha04 Posted February 19, 2008 Report Share Posted February 19, 2008 not to be a dick but if you search down the in the section on the very first page you will see a 2 page long case saver post. have a look Quote Link to comment Share on other sites More sharing options...
bansh4mil Posted February 19, 2008 Author Report Share Posted February 19, 2008 Thanks. I read it and already have a tm designs CS, but I wonder if they have changed them, because it is tight to my 14 tooth. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 19, 2008 Report Share Posted February 19, 2008 Put your 15 tooth on. Then run the chain through it, then hook it up. you might try riding it sloly to see if the chain will wear a clearance. josh Quote Link to comment Share on other sites More sharing options...
bansh4mil Posted February 19, 2008 Author Report Share Posted February 19, 2008 I'll either do that or take my drum sander to it and make it larger. Quote Link to comment Share on other sites More sharing options...
